Question about Watches
How do you adjust ceramic watch band have oniss ladies 601-l have done other watches numerous times this one seems different?
vsndesigns
  • 5 Answers
SOURCE: Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Posted on Feb 09, 2008
  • 77 Answers
SOURCE: Adjusting Band Size on a Movado Amorosa Watch
there are little pins holding them in place pop them ou and add or delete couple links.
Posted on Feb 11, 2008
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
SOURCE: how to open a ladies rolex watch band
Push the crown and lift up the crown part, it will open easily.
Posted on Apr 09, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
I have a men's Oniss watch ON 524m and the band is cracked and broken. Can it be replaced?
You may be able to get a band from a jeweler but im not too sure of your chances.... perhaps contact Oniss and they should be able to help maybe :)
May 07, 2017 | Oniss Watches
I need to take links out of Oniss ceramic watch
Take it to a dealer, a specialist or return it to the retailer and pay to have the bracelet adjusted so you won't have liability for any damage.
Dec 28, 2016 | Oniss Watches
Where would I get a pin that fixes the bracelet to the watch lugs of the following Ceramic Oniss Paris watch. Its rose gold in colour
This is a standard item irrespective of the watch it is for. Just go into any reputable jeweler and they will put it on your watch for about 5 bucks.
Dec 02, 2015 | Oniss Watches
How to take links out of watch band.
there are little holes on the sides,use a tack to push it out on the side,if it doesnt come out on 1 side use the other, https://www.bing.com/videos/search?q=watch+band+pin+removal&FORM=HDRSC3
Jul 18, 2015 | Oniss Paris Womens On626-LRG-BLK Meduse...
How do I replace the battery on my Oniss 612 L
take it to a walmart store and have them do it . unless of course you have a case press to put the back , back on with
Mar 03, 2015 | Oniss Ceramic Watches, Ladies Tungsten...
I have a oniss ceramic dark blue divers watch on8015-MRG. The jeweler can not get one screw out of the back, what can I do?
The jeweller does not have enough tools and or skills to repair the watch. A real watch maker should be able to remove it, even if he broke it. He could even repair the "damage" of a broken screw. Question is, are you prepared to pay for the work, because the job could take over one hour. Use Google to find a watch repair shop close to you.
Jan 20, 2015 | Oniss Watches
Hey there, I just got an Oniss white ceramic watch for my birthday and I raced out to have links removed. No one can do it - two fine jewelry stores and one watch repair place. They said the don't have a...
Wow. Unusual for those places to not be able to do it. The only suggestion I can find since you did exactly what I would have told you (jeweler/watchmaker) I would try the following link:
http://www.watchrepairsusa.com/oniss/watch-repair
Sorry. Best I can come up with unless someone else has some ideals. Good luck.
Aug 13, 2010 | Watches
I have a michael kors white ceramic watch and the band is too long? how do i remove links?
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Jan 15, 2010 | Watches
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Watches Logo
594 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
