Question about GE DVLR223 Dryers
Location of element how do i remove it from the front or back
    President:
  • 2,468 Answers
The element is behind the drum,you must first remove the screws holding the front panel on at the floor area,then lift forward and up like a car hood,then remove top cover screws underneath top cover and lift up like a car hood and secure in upright position as not to tear wire harness,then remove the drum belt and pull drum out of unit,the element can now be accessed and you can order an element re-string kit usually about $25 and re-string the new heating coil yourself
Posted on May 09, 2010
I replaced the heating element and my dryer still won't get hot I have kenmore dryer
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath.
Jun 22, 2012 | Dryers
Heating Element
First you have to determine whether you element is in the front or the back of the machine this is done easiest by looking at the front of the machine and seeingif its one complete piece or two. If its one, the element is in the back, if two its in the front. We'll start if its in the back first. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced. Now if the element is the front everything is the same with the exception of you have to remove the lower portion, usually held on by 3-4 screws located underneath. To replace the element you'll remove the wires that go to the element, and remove the retaining 1/4 " screws so that the element can slide out.
Jun 22, 2012 | Kenmore 600 7962 Dryer
Testing & replacing a dryer heating element
Jun 04, 2012 | Dryers
No heat in dryer.
May 26, 2012 | Kenmore Dryers
Not drying
May 19, 2012 | Whirlpool Dryers
No heat
May 16, 2012 | Whirlpool Dryers
What do I need to replace if my dryer does not heat up? Is it a thermal fuse? and where is it located?
May 05, 2012 | Kenmore Dryers
No heat when drying.
May 01, 2012 | Kenmore Dryers
KEYE778BALO
May 30, 2010 | KitchenAid KEYS700LQ Electric Dryer
Dryer wont heat
Apr 03, 2010 | KitchenAid Dryers
GE DVLR223 Dryers Logo
69 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
