Question about Kodak EasyShare Color Photo Printer Dock
Kodak G610 prints from docked camera, but not from the computer
I have installed the software downloaded from the Kodak web site several times, changed the USB cables with a known working HP 1020 printer, changed USB cables at the powered hub, changed the cable from the hub to a port on the face of the computer, contacted tech support on the phone and tried all their suggestions three times, tried tech support via e-mail and followed all those suggestions, and even exchanged the printer for a new one at Walmart. Computer is an Emachines T2958 running Windows XP Home Edition with fully updated service pack 2. The printer will deliver a photo from a docked Z812 IS camera. I do not get any prints from the computer to the G610 when using Kodak EasyShare software. I can print from within EasyShare to the HP 1020 laser jet printer. The G610 shows up in the list of printers in EasyShare and it is listed under Printers and Faxes in the Control Panel. The print job shows up in the queue for the G610, and that is all that happens. The paper tray is inserted into the printer correctly and the ink cartridge is fresh. I get no messages of any sort when printing is attempted. About the only thing I have not done is buy a new USB cable that is recommended for the G610 from Kodak.
    Problem Solver:
  • 15 Answers
It is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
Posted on Aug 28, 2009
SOURCE:
Kodak Z730 no longer uploads pictures to computer from Easyshare printer dock Series 3 or directly from camera to computer using USB cable
The problem that you describe indicates that your Kodak EasyShare software has somehow become corrupted. Uninstall the software (use the uninstall feature, not just delete) then download and install the current software from the kodak.com web site (this is a no-cost download). That should cure the problem, but if it doesn't I suggest that you contact Kodak customer service via their web site.
Jan 01, 2010 | Kodak EasyShare Z730 Digital Camera
My Kodak G610 printer dock. I can't get the driver to install in my new computer. I have talked to support and chatted also- no results
Dont worry on that you can download your software and drivers and also the firmware of your g610., Just visit this website
kodak.com/go/G610support Now you can just click download software and firmware. for you to see the link of the drivers and firmware
Nov 17, 2009 | Kodak EASYSHARE G610 Thermal Printer
What exactly is a kodak camera dock? I have a M893 IS kodak camera and having difficulty installing the software so I can transfer my photos to computer - so I thought maybe the "kodak camera jack" would...
The Kodak camera dock provides automatic battery charging and automatic connection to your computer when the camera is "docked." There is also a version of the dock that includes a printer, but I have found the printer to be poor quality and very unreliable. The dock must be connected to the computer via USB, and the Kodak EasyShare software must still be installed. The dock is a very handy accessory, but it will not solve your problem. What might help though is a visit to Kodak.com where you can get a free download of the latest EasyShare software that is correct for your operating system.
Oct 21, 2009 | Kodak Easyshare M893 Digital Camera
Computer can't find driver to communicate with printer
can you check if you have the CD that came along with the Kodak Printer? You would need that to install the printer on your computer. Once thats done, you should be able to print the pics
Hope this helps
Thanks
Ranjit
Aug 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Adaptors
Hello
You need "D-26 Adapter"
Compatibility of KODAK EASYSHARE Docks
Best regards,
Zizzler
Apr 22, 2009 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Cant transfer my photos to pc anymore!?!
It maybe that the associated programme you use is not kicking in when the camera is connected ready for downloading. Disconnect your camera dock and re-install the software or driver CD you got with the camera and see if it automatically starts next time you connect. If you can't put your hands on the cd go to this site for software. http://wwwuk.kodak.com/global/en/service/downloads/dln_ekn026079.jhtml?pq-path=4509 Hope it's cured
Nov 27, 2006 | Kodak EasyShare C300 Digital Camera
150 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
