Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
When turning on heat after a period of using air
When turning on heat after a period of using the air conditioning mode, you can hear the furnace going on but the blower does not kick on. You can turn the fan on, but no heat comes from registers. If you can get it to turn on once, usually you don't have any further problems until the next time it's been off for a period of time. The furnace is a Trane gas furnace.
  • 623 Answers
It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
Posted on May 09, 2010
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Can not get fan on to turn on. All else fine. heat only furnace. No air conditioning...only air circulation.I used to set it on "Cool" and "Fan On"and get air to circulate. Do I need new thermostat?
Since you have two thermostats that operate the heating unit and the fan, and the fact that neither will turn the blower on, I would suspect the furnace/ air handler. Turn the thermostat to heat and see if the heat and the fan comes on, if it does operate normally in heat, the fan relay or the high speed on the blower is most likely the culprit. (If the furnace is equipped with a circuit board, the fan relay is integral to the board, if it an older furnace it has a separate fan relay). If it does not operate normally in the heating mode, verify power to the furnace, see if the flame comes on, if it does: the fan motor, circuit board or the fan relay are most likely the cause. hope this helps!
Jul 20, 2015 | Heating & Cooling
Why heater fan will not come on?
Wish I knew how old your furnace is. Let me answer your question directly. In the heat mode the fan runs independently from the air conditioning fan relay. Its either brought on by time or temperature. An old furnace will use a fan and limit control that uses a coil to sense the heat exchanger temperature and turn the fan on or off. Newer furnaces use a timer on a circuit board. 20 years or newer Ill bet its a timer board. Follow the blower motor wires back to the component and ill bet that's the culprit. Hope it helps. Good luck.
Oct 12, 2014 | Heating & Cooling
My Ruud Silhouette gas furnace ugdg 07 model blower stays on. The heat and air both work but it is pricing my energy bill higher. Whats the cause and can I just turn off the power to the unit (what about...
Problem could be the thermostat setting in "fan on" mode. Thermostat could be shorted between Y,R and G. Fan relay points soldered together or main board shorted.
Nov 03, 2013 | Ruud Gas Furnace - Excellent Condition -...
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
Furnace heats up fan turns on then turns off 2min later then back on backoff might finish cycle
Sounds like an air flow problem furnace going off on limit check filter and blower could have a clogged air conditioning. A coil. 20 years plus experience in this fieldl
Jan 18, 2012 | Bryant Heating & Cooling
1992 Dodge Dakota 2wd 3.9L V6 Air conditioning/Heater dosent blow? when i turn the air or the heat on i can hear the compressor kick on but it dosen't blow cold or hot? any help would be appreciated
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
Nov 29, 2011 | 1992 Dodge Dakota
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
199 people viewed this question
Top Omega Tools & Hardware - Others Experts
yoopertech
Terry Hair
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
