Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Continued question on Skewed picture and loss of control functions.
Would the loss of the controls also be a sympton of this issue? I just want to make sure that I do not have a power of other type of error / failure that may be in common with both symptoms; the skewed picture that is gone to b/w and the loss of the controls. It bothers me that even though I continue to have good sound that the controls will not allow the set to change channel or volume or to turn the set off.
Thanks again for you help.
  • 59 Answers
Not all the time but yes I have seen it happen about 60% of the time with the DMD board going bad. But it is possible that the DMD board is not the only problem your TV is having. The digital board (another board in your tv) can cause both these problems at the same time too. It is something that needs to be troubleshooted. But this info will narrow it down for you.
Posted on Mar 27, 2008
SOURCE:
Continued fuel pressure problems in my 01, focus even after fuel pump and filter replacement
emissions vacuum controls leaking or throttle position sensor bad..
Dec 27, 2013 | 2001 Ford Focus
Vauxhall vectra 2.2 power steering problem
Check power steering oil level. If OK and belt is good check p/s idle up control if this sympton occours at low engine revs.
Nov 28, 2012 | Cars & Trucks
Horn won't stop
if you unplug the clock spring on the back side and the horn will stop then remove the air bag and check the switches and wires inside the steering wheel
Aug 17, 2012 | 1999 Dodge Durango
What do u do when your t.v shows red
It depends on the model and brand of the set--some Hitachi and other sets with this issue just need the screen controls (buried inside most sets) adjusted to get a black and white picture.
Some sets have a 3d looking or skewed colors which is a convergence problem---
see attached convergence photos and let me know which issue you have along with the brand/model.
May 29, 2012 | Televison & Video
Nikon d5000 control buttons not functioning. Reset button pressed & reset clock display appears but cannot use any controls.If I reset again with camera on, I get back to display of photo but cannot...
Just found this on the Nikon support website:-
My D5000 does not seem to respond to controls. Can I reset the camera?
In extremely rare instances, unusual characters may appear in the monitor and the camera may stop functioning. In most cases, this phenomenon is caused by a strong external static charge. Turn the camera off, remove and reinsert the battery, taking care to avoid burns, and turn the camera on again, or if you are using an AC adapter (available separately), disconnect and reconnect the adapter and turn the camera on again.
If the problem persists, turn the camera off, open the memory card slot cover, and using a paper clip, gently press the reset button by the memory card slot. ( NOTE: This will also reset the camera clock. Also note that disconnecting the power source or pressing the reset button may result in loss of any data not recorded to the memory card at the time the problem occurred. Data already recorded to the card will not be affected. In the event of continued malfunction, contact your retailer or Nikon-authorized service representative.
There's more info here:- http://support.nikonusa.com/app/answers/list/p/19
Just type D5000 in the search box
Apr 24, 2011 | Cameras
I get a error initializing scanner?
Background of issue- When 4345/M4345 boots up, amber light comes on under start button and the message "Initializing Scanner" is displayed. The unit will print but will not preform any scan functions.
Steps taken to try to resolve issue:
1. Updated firmware
2. Restored factory defaults
3. Took off cover in back of printer covering scanner controller board and reseated all cables
4. Took apart scan unit and cleaned (2)mirrors in scan head
5. Took off back cover of unit, reseated cables coming from scanner controller board
6. Ran Scanner Test, in menu (which everything functions properly)
Usually I would say scanner or controller board has failed but I had 3 M4345 come down with this issue in one week. The only resolve i've found for this issue is repetitively turning on and off the unit until it comes up without "scanner initializing" message. Once it comes up it functions 100% until the unit is turned off and issue will come back.
I'm at a loss here with so many units having same issue, open to any advice. I once took the formatter out of bad unit and put it in good one and it caused the issue in the good one but i'm double verifying this tonight. Thanks for any help.
Nov 17, 2010 | HP LaserJet 4345mfp Printer
First of all my tv gives me trouble to come on and when it doe sit stays on for approximately 15 - 20seconds and then turns itself right back off.Also when I try to use the control buttons for the volume...
Hi:
This manufacture is notorious for system control board failue problems, most failures of this unit can be common to the Main Board assembly, and the inverter circuits. considering you symptons you will need to replace the Main board assembly.
Aug 24, 2010 | Norcent Technologies LT-2720 27 in....
DISTORTED PICTURE
in your tv there is a light engine ballast.that light engine ballast controls the colour /picture quality.that engine is got faulty and that needs replacement.if the picture with distorted also looks dim then there is a lamp that also needs replacement with lightengine ballast.but if the picture is distorted but bright then no lamp replacement only light engine ballast.
this is very costly issue to get replaced.near to $350 plus the service charge of the technician who replaces the component.
thank you for using fixya.
Apr 03, 2009 | Televison & Video
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
