Question about Tools & Hardware - Others
Hello, I have a Challenge Xtreme Grass Trimmer PRT 350T 350 watts cutting width 250mm and I need a new spool and line but have no idea which one to buy. I hope you can help me. Thank you.
3 Suggested Answers
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
Posted on Jul 09, 2008
bbreton
  • 437 Answers
SOURCE: trimmer line on spool of Challenge 250 Watt Grass
I did a lot of searching for a manual but I guess Argos does not want their customers to know how to use their product. When you are use the trimmer, most rotate clockwise. You may find on the spool an arrow showing direction to wind line. Otherwise you will have to take it apart the trimmer and remember with direction the spool turns. Wind the string on the same direction turns. plus try a little wd40 on the line to keep it from sticking together.
Cheers.
Posted on Oct 12, 2009
Pineapple leaf jammed under spool housing. How to remove housing to clean out?
Usually the cutting heads have a couple of plastic tabs you push in to release the spool from the head
Mar 06, 2016 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
How do you replace the cutting line
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 11, 2012 | Ryobi Garden
I just got a grass hog trimmer that used to belong to my sister. The line is not feeding and I don't know how to restring.
The cap on the bottom pops off, and there is a spool in there. Sometimes the line melts to itself in spots and you just have to free it and if you feel you need to then you can cut some off.
I hope this helps you out.
Jul 27, 2011 | Black & Decker 14" Grass Hog Xp...
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
NEED INSTRUCTION SHEET FOR LINE INSTALLATION
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 25, 2009 | Garden
Trimmer line on spool of Challenge 250 Watt Grass Trimmer.will not automatically feed as it is supposed to do when tapped on firm surface - can you let me see by diagram how the line is feed onto spool and...
Cheers.
Oct 12, 2009 | Garden
Installing new line on my string grass trimmer
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Tools & Hardware - Others Logo
52 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
