Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive washer My washer stops after the wash cyle with water still in the drum and the errow message says"fault 37" I read someone else had a similar problem and was advised to check and clean the filter. Can anyone tell mw where this filter is located and how to get to it? Thanks
  • 3 more comments
  • barkwaffle Mar 31, 2008
    Help! Same problem with EcoSmart washing machine. Drum full of water, pump will not come on after wash cycle, just stays full and beeps. Is there a filter - and how to access and clean?
    thx
  • mrspaws Apr 04, 2008
    same thing here. Won't drain, just beeps.
  • urangias Sep 01, 2008
    yep mine has the same problem it keeps saying needs service fault code 37, i rang a srvice person they seem to think its a blocked pump how do you unblock the pump????
  • ray73k Dec 26, 2008
    WE HAVE THE SAME PROBLEM AS WELL, ITS DRIVING US NUTS AS WE HAVE DONE EVERYTHING THAT HAS BEEN POSTED ON THE NET. A NEW ONE POSTED SAYS TO CHECK THE Y MANIFOLD UNDERNEATH THE MACHINE WHICH WE DID BUT HOW CAN YOU TELL IF IT NEEDS TO BE REPLACED OR NOT?
  • 22tango Feb 01, 2009
    my washer washes then stops on the rinse cycle 'needs service fault 37 ' comes up
  • 27 Answers
Lets clear this one up. There is not filter on a Smart Drive, Yon will need to removed the top deck of the machine, then the agitator, then the inner bowl. You will then be able to access the pump cover (front right hand side of outer bowl). Removed the screw retaining the cover, then remove the obstruction, it will probably be hair clips, bra underwires etc
Posted on Sep 23, 2008
Had the same problem, fault code 37. Followed Neil_v advice and found one of the kids socks blocking the pump, works fine. Gave the bowl a good clean at the same time, amazing how much slim builds up on the outside of the bowl, a wonder it washed anything.
Posted on Apr 03, 2009
I had the same problem years ago, machine would just shut down was a stuffed water pump. Changed the pump and is still going strong !! Hope this helps.
Posted on Apr 12, 2009
Neil-v you are a legend. Had the same problem today - googled fault 37, found your solution and hey presto, half an hour later all is well. It was due to a hair pin and a piece of plastic (not from the washing machine) blocking the pump
Thank you very much.
Posted on Apr 09, 2009
Same problem with fault 37 and there was some cotton in this pump area. But also found by backflushing the outlet hose, I found more cotton there and later realised it was due to a kink in the hose. It all is well now.
Posted on Apr 05, 2009
We have a problem with our washing machine Intuitive Eco saying it has fault 37. What is that problem please
I believe that is a weter can't drain fault message. Have you checked to make sure your drain hose is not kinked, and that the drain is accepting water?
Feb 10, 2011 | Washing Machines
We have a fisher and paykel intuitive eco, which says code 37,
Hi just read your posting.Now ERROR CODE 37 means PUMP BLOCK ERROR.Is your machine draining any of the water out of it?Please reply with additional information on the question and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel Washing Machines
My washer has fault 37 and we can smell rubber burning. The drum feels very lose.
On F&P machines the inner tub floats away from the dog clutch allowing the agitator to wash without attachment to the drum. When you empty the machine the inner drum settles back on the dog clutch and can be engaged for spinning. A loose drum when full of water is probably not a fault..
37 error is pump fault. Water level not changing.
The pump may be blocked/jammed and be overheating, or it may have failed.
You'll need to unplug the power supply at the socket.
You'll need to empty the machine.
When the water level is low you can lean the machine back to access the pump motor under the tub. Turning the fan blades can sometimes dislodge the obstruction. If the fan turns freely retry the spin mode to empty the machine..
If the pump is jammed you'll have to remove it and clear the port.
Make sure you've emptied the machine as any water left in it will run out when you remove the pump.
carefully study the pump before removal. Take note of the latch which locks the pump in position. Earth wire to open spade connector. Power wires to pump via plug. Remove and clean. Replace and test.
If the pump still overheats it should be replaced or it will damage other components. The pump resistance should be more that 33ohms..
F&P reccommend pump replacement if less than 33ohms.
Good luck.....Nomess
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Jul 04, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&paykle washing machine, intuitive eco. fault 37
hi
fault 37 is usually associated with the pump not pumping out all the water in time
cheers grant
Oct 21, 2008 | Washing Machines
Fisher and Paykel Intuitive Eco Washing Machine
The drain pump is overheating. I suggest you do not try to use the machine until you replace the pump unit, failure to stop using the machine will result in the pump short circuiting and destroying the main control board!. Please go buy a new pump and fit it.
Sep 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
574 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
