Question about Logitech X-240 Computer Speakers
Can't hook up Logitech x-240 speakers properly
I've moved and seem to be doing something wrong cos either getting bass and no treble or the opposite. Sub-woofer is plugged into mains, there are 2 other speakers and a plug that should go into either the power/volume box or the sub-woofer and I'm scared of breaking them by doing the wrong thing. Actually I'm sure I've tried both and neither worked but if anyone knows what I should be doing please help. I've always noticed quite a loud buzz so maybe I've always done it wrong...
5 Suggested Answers
  • 5 Answers
SOURCE: Sub Woofer Not Working
Make sure it is plugged in and the volume is up. Also make sure you don't have your sound muted. Do any sounds come out of your computer? Go to the control panel and click sounds and do a test.
Posted on Dec 25, 2007
Open SKy
  • 618 Answers
SOURCE: need instalation instructions
Usually the speaker setup is easy, connecting with the manual all the respective cables, and the black , green, orange, to the back out to the Sound card. if you have of course I presume a 5.1 sound card. if not, just use the green cable to the green on the sound card, and black according.
you have to connect the SUB alone and send the green and black signals to the port on the sound card.
good luck
Posted on Nov 15, 2007
  • 3 Answers
SOURCE: How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
DaveMc3
  • 32 Answers
SOURCE: sub woofer got weak
If there is an adjustment, turn up the subwoofer volume. After you started shaking the house somebody may have adjusted it for you.
Check your computer control panels volume too, cause they may have a subwoofer volume there too.
If there is an equalizer (software) then make sure the low frequencies are set properly (middle or above). Check for this in your computer audio control panels.
If there is no adjustment anywhere, take it back, 'cause it is busted. If it is too late to take it back, sent it to logitech for repair under warranty. If it is too late for that, go buy a new one.
--Dave
Posted on Feb 07, 2010
Testimonial: "thank you very much all my adjustments are the same it must be busted."
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
I want to reduce the bass on my logitech X-210 speakers.
Go to speaker icon bottom right corner of screen.
Right click and choose audio options
You should have sliders for bass,treble,volume etc
Jun 22, 2011 | Logitech X210 2 Speakers
No sound
If you know your speakers are working and there is nothing wrong with them go on your computer and go to sound settings in control panel and adjust treble bass and volume.
May 30, 2010 | Insignia 2.0 Speaker System (2-Piece)
Bass problems
At the audio mixer settings choose playback and look for something like "for advanced users" or like that. Here you will find the BASS - TREBLE control. In some older audio cards there isn't any selection like that.
Stelios.
Feb 20, 2010 | Inland ProSound 2000 Computer Speakers
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Cinemate bose how do I adjust base and trebble
If the system doesn't have controls labeled "bass" and "treble" - or if there are no clever presets like "Hall", "Theater", etc., then you'll have to adjust these parameters before the signal reaches the speakers. One way is to purchase a graphic equalizer to hook between the speakers and the signal source. A graphic equalizer a basically a tone control, with the spectrum divided into 10 or more "slices" instead of 2 (bass and treble). Consider the sliders on the left as "bass", and the ones on the right as "treble". If you're using these speakers for a computer, some sound card software has these controls buried beneath a few menus - but sometimes not. The easiest solution is to buy an equalizer and hook it between the signal source and speakers. Bose is typically "audiophile" equipment, and many audiophiles don't want tone controls (thus the extra electronic processing required) to contaminate the signal. Obviously, most systems do need to offer some control to the user, as you've discovered!
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Logitech X-240 Computer Speakers Logo
124 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
