FixYa.com
Tags:
Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jennair stove door locked (by 3 users)
posted by maxgustav on Mar 27, 2008
my tenant moved out and run a cleaning cycle. Since this time the door does not open anymore, stove was not used in the meantime
Thank you for your tips and help
Max
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by BobVenard, posted on Apr 05, 2008
occasionally the stove will lock door and display F9. It will not clear until stove cools off and then door will disengage when clear is pressed. Is this a thermostat problem or an electric fault.
Comment by Little Pat, posted on Mar 28, 2008
door locked want open
Best Solution
posted on Mar 29, 2008
Thanks for Trying (70)
gwshaw71
Rank:Guru Guru
Rating: 87%, 61 votes
there is a thermostat on rear of oven that has gone bad.Unplug unit remove back panel and you will find it there.You can also undo your locking mech. and put back togather to get door open.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Ranges problems?
Jenn-Air SVE47100 Slide-In Electric Kitchen...
Spacer for back of Range
Does Jenn Air make a spacer for... Answer This...
Oven Door
A lighting strike toasted the... Answer This...
I got a F2 error
I got a F2 error code on the... Answer This...
starting the cleaning cycle??
how do you get the oven to go... Answer This...
F1 reading
Used self clean, after finished... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
