I have a Mitsubishi vs-4571 rear projection tv tat has audio, however the screen is black. You can hear it click on and off but will not display any picture. Wondering a round about price to fix this problem.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Also please check that the lamp is fine. Resistors will change value and burn. This will cause other components to become defective. This can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. If one IC is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 09, 2010
Picture tube for 60 in' mitsubishi it shows only a black screen but you can still hear it
ts will go into shutdown when a vertical issue is present but the audio will still continue to operate normally.
Apr 02, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Sound is O.K. no picture?
mitsubishi vs4561c projection tv no picture screen is blue sound is ok
Dec 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Vs 4571
you must replaces many electricaly capacitors located on video board
good luck!!
Aug 18, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
Shuttle83
May 31, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Mithubishi projection tv VS 4571
Try resoldering the vertical output IC if that doesnt help your IC may be faulty and need replacement
May 10, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi 60" Model VS-6047
going into shut down why well ther emay be couple reason bad voltage regulator no b+ relay bad or open solder joints call tv reair shop
Feb 11, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
