Do anyone know what e11 mean on hotpoint wd71 pls
I got a hotpoint ultima 1200 wd71 abt few minute into washing and normal speed washing i get a warning to check water supplies e11 come up i check the water and from the main it fine but i did notice the drain pipe from the washing machine didnt flush out and just wonder if it was the pump had gone ?
  • jamesreed999 Feb 18, 2009
    Did you find a solution?
    I have the same problem - water into the machine no probs but error code E11 keeps stopping the cycle. Is it the water valve on the inlet pipes?
    Problem Solver:
  • 3 Answers
It means "No hot/cold fill" and recommends - Check the water supply, inlet valve and hot and cold hose connections.
Posted on May 14, 2008
SOURCE:
Where is the 7.5 amp fuse in the hotpoint WD71?
the 7.5 amp fuse is near the power module, This fuse is on the motor circuit to protect the circuitry of the power module. If it blows the motor won't work .hope this helps
Dec 22, 2009 | Hotpoint Ultima WD72 Front Load...
DOOR WONT CLOSED WD71 HOTPOINT AQUARIUS ULTIMA WASHER 1200
you can try unplugging the unit for a few minutes and see if that resets, otherwise its a faulty sensor that needs to be replaced.
Nov 06, 2009 | Washing Machines
Error 16 on hotpoint wd71 n what does it mean???
F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer
Mar 12, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD71 - floods on drying programme
you may have a hose loose or holed at the inside rear of the machine.
Jan 04, 2009 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
668 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
