Question about Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp picture "shifts up"
I have a Dell 1907FP for about a year an a half that was working flawlessly. Since a few days, the monitor picture is "shifting up". It is connected by DVI to a nVIDIA 8500 GT.
The problem is that some "lines" disapear and the rest of the display "shifts up", leaving black space at the bottom of the monitor. The problem is intermittent. I've plugged the monitor with a DB15 VGA cable and the problem seems to have disappeared. I want to by another cable to test but I want some advice before I spend money on that.
  • 74 Answers
It is most likely the cable, it is where most faults of this ilk lie in LCD monitors. :-)
Posted on Mar 27, 2008
6ya staff
SOURCE:
Dell ultrasharp 1907fp bad contrast
I have seen a few of these monitors that when the display is dark in certan area's this usually indicates that one of the CCFL lamps has gone bad or there is a problem with the Analog/Digital Board, you can find the boards on ebay, but be VERY Certain that the board you order is the same that you take out of the monitor, as there are a lot of monitors that use the same simular boards but they are all different.
Sep 24, 2012 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell LCD 1907FP 19" have
Unfortunately this is an early indicator that the LCD display panel is starting to break down and the cost to replace the part will exceed the amount of a new monitor. I recommend using present item until it completely fails. Sometimes the video cable is the issue and should be subbed provided you can detach from both ends.
Sep 06, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
Where can I find an on/off switch for my Dell 1907FP monitor?
sholmes, Try Digikey.com or Mouser electronics. You WILL match it up exactly and may need to do some tricky "unsoldering" and "soldering". Good luck! YOU'RE on your OWN. 12fixlouie.
Nov 18, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
102 people viewed this question
Ekse
Clive
Clive
Alun Cox
