Question about IBM Wheelwriter 30 Typewriter
Help with ibm typewriter
While I'm typing, the platform that holds the ribbon cartridge does not move up and down like it should. It either sticks up or down. Please help. We had a pretty bad power outage/surge the other day and I think it fried one of the components. Plus, if I need it to be serviced, where can I found out who to call. Thank you!
  • IBM Master
  • 3,594 Answers
It sounds like the function board or the printer motor is bad.
If you can get it to us I'm sure we can repair it. We are in Cleveland, Ohio.
[email protected]
DickyO
Posted on Mar 28, 2008
SOURCE:
Cartridge for ibm 6784. where can i get?
have you tried going to:
georgebeyers.com
Jun 12, 2013 | Office Equipment & Supplies
The typewriter ribbon does not want to turn when typing
If you have moved the red lever from the front to thje right and it dosen't feed be sure the ribbon is to the L. of the slacker finger where the ribbon comes out of the cartridge if that is OK try some WD40 on thearm with the spiked driver on th end they do gum up and not engage the ribbon.
DickyO
Mar 05, 2013 | IBM Correcting Selectric Iii Typewriter...
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
Older IBM Wheelwriter 1500 typewriter won't print
First put in a milti part form or a carbon, type, if it prints in the copy your ribbon isn't lifting, if this is the problem put some WD40 ON THE UPPER AND LOWER RIBBON MOTOR, IT IS just below the ribbon deck on the right. If there is no print the print solenoid cap is probably broken.
We sell the cap for 20.00 includes instructions and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Oct 15, 2009 | IBM Office Equipment & Supplies
My ribbon broke, I don' t know how to fix it.
The ribbon has 2 little (feet) on the rear of the cartridge they hook into the ribbon deck and it just rocks into place. You can get a picture and instructions @ lexmark .com klick your way to publications. Be sure to advance the ribbon by hand a foot or so to be sure it isn't sticking to itself.
DickyO
Sep 29, 2009 | Lexmark Wheelwriter 3 Typewriter
Can't get my new cartridge installed into my
Move the red lever clockwise until it points to you, remove the ribbon, drop the new ribbon in, from the left side it goes to the left of the white slacker finger thru the two ribbon guides and back to the spool. Be sure to take up the slack by turning the knob in the direction of the arrows. NOTE: The red lever will not move if the grey correction is opened.
DickyO
Jun 30, 2009 | IBM Office Equipment & Supplies
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Easystrike Cartridges
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Feb 08, 2008 | Lexmark Wheelwriter 3 Typewriter
IBM Selectric III - ribbon won't turn
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Jan 20, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 30 Typewriter Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
