Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Cannot format my MY Passport HDD 250GB...Showing ERROR in Erase!
Dont know what happend...i never dropped my harddisk...i always make sure that i remove it through the Safely Remove Device Option n wait till the running of the harddisk stops before i unplug the usb.
Recently i tried formattin it by the Drive Erase option in the settings menu of the WD software of the harddisk..which then said there was an error in erasing...n then it just crashes..then im not able to enter the harddisk...until i unplug n reconnect again....there seems to be some system error with the harddisk...but cant figure out what it is
So pleasee guyss...i really need your help soon...i cant lose my hardisk...my girlfriend got it for me on my birthday, it will be really heartbreakin...its only been a lil more than a month since i got it...
U guys are my only hope!!
thnks a ton!!!!!!!!!!!
  • 1,555 Answers
You shall once more format the HDD but this time don't opt for quick format. This time select create a MS Dos bootable. Once you have formatted and if success it will work. You have 90% chances it will work. If it doesn't comment back will give you another option to make it work.
Posted on May 09, 2010
Hdd problem not detect
Try to get Acronis Disk Director. This program is able to read and format your harddisk, even when Windows is not able to see it (*). With the mentioned software, you can format the disk and make it readable for Windows.
(*) Maybe it's not formatted, or contains a file-format which Windows does not recognise, like what happened, when this disk was previously formatted for UNIX/Linux-systems. With Acronis you can overcome this problem.
Oct 11, 2013 | Samsung HDD 250GB SATA 25 HM251JJ SATA...
How to install it on Mac
p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Thanks for your email. The Western Digital WD Passport comes formatted for a PC, so it does require that you format the drive so that the Mac can recognize it. First, open Disk Utility with the drive connected and running. Then, choose the drive on the left side, then choose the Partition Tab. Change the Current Partition to one, or the number of partitions you would like, then click Options. Here you will change the Partition Map Scheme to GUID, then click OK. Then in the Format Menu drop down choose Mac OS Extended (Journaled), then click Apply and OK. Your drive will now be formatted for a Mac. To format the drive for cross-platform use, make sure that you have backed up all your data from the drive as formatting will destroy any data on the drive. First, connect the drive to your Mac, and open Disk Utility. Then select your drive on the left side of the window and choose the Partition Tab. Then change the Current Partition drop-down menu to 1 partition and click on the Options button. A new window will appear where you will choose Master Boot Record (MBR), then click OK. Then choose Free Space from the Format drop-down menu, click Apply, then OK. Your drive will now appear unformatted. Then choose the Erase tab, choose FAT32 as the Format, name your drive (you will be limited to 11 characters), and click Erase, then OK. Your drive will then appear on the desktop formatted for cross-platform use, and you can copy the data you need to move to your PC and then connect the drive to your PC. If formatting is not an option, the you can buy a program such as MacDrive that will allow your PC to read and write Mac OS files.
Apr 18, 2011 | Western Digital WD Passport 250GB Portable...
I need to know how to reformat my passport for mac.
go to spotlight, the magnify glass at the top right corner
type in disk utility
select it
from there select the WD hard drive
go to erase tab
choose mac extended journal
click format to erase and format the disk for MAC.
Please note this will make the hard drive viewable for MAC devices only.
if you wish to use it on MAC or PC use FAT as the filesystem format.
Mar 13, 2011 | Western Digital WD Passport 250GB Portable...
My western digital wd passport 250gb shows up as drive "d" but goes away
Make sure it is connected properly, normally when this happend it means the USB connection is loose.
Feb 15, 2011 | Western Digital WD Passport 250GB Portable...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
PC doesn't recognize Passport after Mac use
you must choose the format you wanna run on your hdd.mac and pc aren't the same.
Apr 16, 2010 | Western Digital WD Passport 250GB Portable...
I have an asus a7v400-mx ver 1.03 mother board + 250gb hdd
have you tried "my computer"to see all the drives. By right clicking on each/properties you should be able to id which drive it is by letter (C;D;E;ECT.)now, close that window;right click on the drive it was id'd as MAKE SURE YOU HAVE THE RIGHT DRIVE, right click; chose format. XP should format and partion for you(I'm assuming this is a new 2nd hdd.
Mar 20, 2010 | ASUS A7V400-MX Motherboard
Sony Camcorder HDD error
Hi There ...anyhow i have solved this problem
Regards,
Lionel
Nov 17, 2009 | Sony HDR-XR100 AVC Camcorder
Bad sectors of my hard drive
There's no concrete way, you can try these software:
May 27, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
809 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
