My tv makes a very loud humming noise when you increase the sound. Therefore cannot increase the sound at all and have to keep the volume to a minimum level. how can this be fixed?
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help Ā· Burning in of static ...
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV. 2. Look at the power supply board..Its normally connected to the power cord.. 3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors.. 4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value.. 5. Some of the capacitors not bulged so its better if have a capacitance meter
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
