Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I can't get my new ipad to recognize my network. I have a laptop that connects to it. The iPad seems to recognize another neighborhood network that is not mine.
casouzaj
  • 1118 Answers
SOURCE: 3 computers connected, can't connect ipad and wii
I remember having had problems to connect my son's Wii console to our router. After many tries and errors, I set the router's encryption method to WPA-PSK/TKIP with pasword update cycles disabled (In my case 'Group Key Update Period' set to 0 (zero)), and, since then, the Wii connects to our router whenever we want it to.
You could try to set yours this way to see how it goes.
Just my 2 cents... Carlos
Posted on May 17, 2010
  • 22 Answers
SOURCE: ipad connects to D-Link DI-524, authenticates and
I think the problem is that your router has a firewall that your iPad can't get through.
You could try going to D-Link's web site and find directions to allow your iPad to access the internet.
=) hope this helps
Posted on Jul 10, 2010
  • 324 Answers
SOURCE: how i connect dlink access point in apple ipad
in your apple ipad switch on your wireless and search for the available networks you can find your router name just click that it will ask for the wep key its nothing but your wireless password you need to enter that then it will connect automatically
Posted on Jul 28, 2010
rcw1962
  • 2571 Answers
SOURCE: my linksys router will now
usually with the IPAD. You need to put the correct settings into the wireless connection settings.
You wll need your SSID (the name your router shows up as when you search for wireless connections)
Your security type ( WEP or WPA/WPA2)
your wifi password.
I have connected many IPADS, as long as you have the correct details it should work
Are you setting the correct security type?
Posted on Aug 08, 2010
  • 33 Answers
SOURCE: Can't get my IPad to
Check the Wireless Settings on Router
try changing the Transmit channel to 06 or 11
All the BEST
Posted on Oct 08, 2010
Setting up my iPad to use chromecast
what provider?
are you using their equipment ?
did the router or network name change or password?
Are you certain both chromecast and ipad are connecting to same network ?
chromecast only works on 2.4ghz networks
can you use your phone or another device
sounds like cast is trying to connect to old network and ipad is on new network
Nov 10, 2016 | Apple iPad Tablets & eReaders
How to connect to internet doesnt recognize router password
Are you sure of Wifi password is correct?
if so, 1st; try restarting your ipad by holding down power/sleep button untill it show "Slide to shut down" leave it off for 10 seconds & then re-open it.enter the Wifi -password, sometimes this step works.
2nd solution ; try resetting your iPad network settings, it will not affect your ipad in any thing except it will forget all entered passwords for any wifi you have already connected before. go to General from Setting, choose resett, and inside only reset network setting, shut down ipad & try to connect to the wifi again. Hope this solution work for you. Also you may try shutting down & opening your router again after 10 seconds while off. Good Luck.
May 19, 2016 | Apple iPad Mini
How do I add my iPad to my printer?
other way around - you need add printer to your ipad, you did not write what printer model and name, you did not supply information if it is this on wireless network or it is wireless printer, without that information help is not possible...
telepathy is overrated... work only in the movies...
Dec 28, 2014 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I can't connect to ITunes
connect the pad to your computer and open iTunes, turn off the ipad, then hold both the lock and the home button for 10 seconds, then release the lock button while continuing to hold the home button until iTunes recognizes the iPad.
iOS Device not recognized in iTunes for OS
Jun 18, 2014 | Apple iPad Tablets & eReaders
I have installed connectify on my windows 7 toshiba laptop. when i start it, the connection work well on my ipad for about 5 minutes and after it s get disconnected. each time i just close the wifi access...
1- I don't know what connectify is or even why you would use it. Your router can or should be able to handle wireless communications in your WiFi network. Once you have your wifi network setup under the router then go into settings on your ipad and point it to the right network and it should connect.
2- On your toshiba it should connect on it's own as well, get the wifi connection setup the go into network connection and point it to your wireless network in the house.
Like i said i don't know why or what this other program is or even for but see no good reason to even use it.
Hope this helps
Feb 21, 2014 | Computers & Internet
IPad USB problems
http://www.iskysoft.com/apple-ipad/connect-ipad-to-itunes.html
this is so workfu!!!
tablette pc
lecteur ebook
Feb 22, 2012 | Apple iPad (16 GB) WiFi Tablet PC
I have a Netgear router Model # WGR614 v7. The new Ipad cannot connect unless I tell it to forget that netwok, then reset network settings. I then unplug the router, leave it a minute or two & then...
What version of iOS is the iPad running? Try updating the iPad to the latest version of iOS (4.3.1) and see if the wireless situation is better.
To update the iOS, just plug the iPad into you computer and look in iTunes to see if an update is available for the iPad.
Apr 16, 2011 | NetGear WGR614 Wireless Router
I had bought an ipad wifii and a new mtnl wifii connection last week. My mac could connect to the wifii network seamlessly, but am facing problems with ipad connectivity. Ipad could connect with the...
there were some random wifi issues with ipads early on but the most recent updates through itunes have corrected those. So best thing would be to connect to your computer and make sure its updated. if that doesn't work, may be a range issue, they dont have the longest reception.
Mar 31, 2011 | Apple iPad 64 GB 3G Tablet PC
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
161 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
