Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi Gas trimmer fuel line routing
I can't figure out the routing for the fuel lines on a Ryobi 700r gas trimmer. I have a hard time figuring out how two "Guru Rank" responses have opposite routing info.
It seems logical that the inlet end of the carb would be a gravity feed
so saying that the filter line would first go into the primer inlet doesn't make sense.
The "mdmcdowel" way has the primer bulb stuck on suction when I prime it (filter line to primer bulb suction).
The "mrfixit-jerr" way has the action of sucking fuel through the filter line through the carb via the return line, this way has air and fuel in the return line meanwhile the filter line is full.
Questions:
1. Should the return line have air with fuel as you're priming?
2. Should the carb inlet be a direct gravity feed?
3. Does the primer work by sucking fuel through the carb as opposed to pumping fuel in?
4. Are there markings on the carb to inlet and return?
Thanks in Advance
  • 284 Answers
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
Posted on May 09, 2010
Testimonial: "Thank you"
The primer bulb is broken on my 700r 2-Cycle Gas Trimmer and I would like to replace it
not difficult at all to do , first obtain Ryobi primer /fuel line kit from your local distributor , then remove air cleaner cover (pops off with fingers) then drain all gas from fuel tank back into storage tank , locate the two Phillips head screws next to primer bulb and remove them , careful not to drop them !! remove old bulb from ring and replace with new bulb from pkg. then using a clean cloth , carefully wipe out sealing grove where bulb seats down (I guarantee its dirty) when all clean , place bulb down in grove and make sure it seats well then secure with ring and replace screws (don't over tighten) you might as well replace the fuel lines as they come in kit , instructions are on pkg , I do suggest doing one at a time to not forget how they go , and do use the new fuel filter that's inside pkg too
May 13, 2016 | Ryobi Garden
Gas line hose routing on a ryobi 700r can i get a digram
Check the search feature on this forum for FUEL LINE ROUTING.Much has been written on this popular subject in these forums. Thanks.
Aug 17, 2010 | Ryobi Garden
Ryobi 700r gas trimmer. Leaking fuel from the fuel return line...what is the best way to fix this?...seems to be leaking where the tube goes up into the fuel tank. thanks.
There is no nipple. The fuel line is just pushed through and holds itself tight against the hole in the tank.
This is the return line from the primer bulb, right?
Just replace the line and you should be fine. I think that some of these Ryobi lines are 3/16 OD and 3/32 ID, but I just picked up a Ryobi fuel line kit at Home Depot today, and the black line seems to fit nicely here. (My trimmer still won't start, but at least it doesn't leak gas any more.) Be careful to note which line comes from where on the orimer bulb.
Steve
May 12, 2010 | Garden
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
Existing gas line fell aport. Have new hose but need gas line routing for Ryobi leaf blower.
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
HERE IS THE PARTS BREAKDOWN OF A RYOBI/MTD/RYAN ENGINE.....THE BEST THING I CAN DO WITH OUT PHISICALLY SHOWING YOU. HOPE THIS HELPS AND GOOD LUCK
Nov 23, 2009 | Ryobi Garden
My ryobi 31cc 15" 700r won't start
You need to push the primer button 10 times or so (the button at the top of the speed control) to get the gass pumped up into the system again. Likely gas not getting through the line yet. Takes awhile.
May 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
2,333 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
