Question about Dualit 88400 Hand Mixer
How do you get into the mixer - Dualit 88400 Hand Mixer
To gain access to the gear housing you will need a small flat bladed screwdriver and a 15mm A/F hexagon bar (Allen key).
Insert the screwdriver into the small rectangular slot located at the front end of the base plate.
Insert the hexagonal bar into the recess on the base plate.
With the screwdriver, gently release the plastic retaining finger by deflecting it towards the rear of the machine at the same time turning the hexagon bar clockwise to release the bayonet locking mechanism.
The base plate can then be lifted free of the mixer body.
The retaining screw located immediately below the base plate and to the rear of the opening can be removed to enable the motor assembly to be slid rearwards BUT I haven't yet worked out how to disconnect the switch from the motor to enable complete removal.
Colin A.
Posted on Nov 07, 2014
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
The head on my mixer will not go back
Note, electric mixers are great to have around, whether the stand or hand-held type. For those of us that use one on practically a daily basis, here are few instruction below on how to fix an electric mixer.
Instructions
  1. Unplug the mixer before attempting any type of repair. If the mixer has a lot of batter and food on it, clean the appliance. A lot of times while using the mixer, the ingredients can work their way up the beaters and make their way into the gear section where the beaters attach. This can happen especially when mixing bread dough, cookie batter or any dense or heavy ingredients.
  2. Refer to owner's manuals when fixing an electric mixer. If the mixer stops beating when it's turned on, it could be that the appliance isn't getting the proper voltage. Test the mixer using a voltmeter. If the mixer is getting the proper voltage, it could be that one of the gears are worn out.
  3. Check the wiring on the mixer. Look for any cracks, tears or exposed wires. Sometimes just using electrical tape to repair the cord is all that's needed.
  4. Take out the screws from underneath the head of the mixer using a Phillips screwdriver. Next take out the screws on the back of the head of the mixer (some brands have these, others don't).
  5. Grasp the head of the mixer and gently pry off the housing with a large screwdriver. A slot screwdriver is preferable. Clean out the area with a soft cloth and look for any broken parts or wires.
  6. Go directly to the website of the brand of mixer you have. Most major brands will offer advice and suggestions for proper maintenance.
Good luck and thanks for using fixya.
Jan 15, 2011 | Sunbeam Heritage 2346 Stand Mixer
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Feb 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Broken mixer blades on a bravetti 300watt hand held mixer
Bravetti Mixer Beaters 10+ Bravetti Products Shop, Compare and Save at Pronto.Bravetti.Pronto.com
Nov 02, 2009 | Bravetti 130 Watts EP524H Hand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
Dualit 88400 Hand Mixer Logo
551 people viewed this question
Top Dualit Food Mixers Experts
eyecam
Are you a Dualit Food Mixer Expert? Answer questions, earn points and help others
