Question about ViewSonic VX1935wm LCD Monitor
The monitor shows black when I power up my computer in the morning. When I turn the monitor off, then on, I get a picture for a few seconds with analog in the upper right corner, then it goes black again. Pushing the first button once usually corrects the situation. What is going on?
  • Louis Ebert May 15, 2010
    Joyous_81, The very next time it displays a full screen and then goes "black", please point a bright flashilght 1 inch (3cm) from screen to see if unit is displaying anything even though screen is "black". If you see the very faint image of the Win-desktop with icons units internal power supply is in "partial shutdown" mode. If you see nothing units switch-mode-power-supply may be in Full shutdown mode. In either case you will need to spend some time reading in the fixya profiles of "louie12fix", "budmrtn" and "buddymc" and follow the links you find there to learn why unit failed and your options for repair. Yes, you can also try moving and connecting unit to an already fully booted "known good" pc running Windows XP to see if unit still "acts" strange. Let us know how you fair with this unit. Do a second comment here at fixya so all others will know also. 12fixlouie
  • 80 Answers
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Syncmaster 740n was working fine but has not gone black when i turned it on this morning and now i cant see anything, ive put it onto another computer but its still black and not showing anything sumtimes...
This sounds like the inverter power supply has gone out. This is a very common problem for LCD monitors after a few years.In the 740N monitors they used two different power supplies but both had the same problems. If you can open the monitor and take a few pictures of the board and email them to me at tech@ccl-la.com I will tell you what needs to be done on that version of board. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping.
Buddy
Corporate Computer
www.ccl-la.com
Sep 15, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Hitachi CML174SXW B randomly goes black
Have you noticed if the monitor gets hot before it turns off?
Please, don't open a monitor and try to repair it yourself. It can be very dangerous and it's not worth getting injured.
Jun 18, 2008 | Hitachi CML174SXWB (Carbon) 17" LCD...
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
ViewSonic VX1935wm LCD Monitor Logo
185 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
