Question about Philips 37PF5521D 37 in. HD-Ready LCD Television
My Philips 37PF5521D 37in TV has no sound and the green light keeps flashing , what is the problem and how much will it cose to repair ?
  • 476 Answers
SOURCE: SETANTA
If Setanta shows up as a channel, but is just not accessible, then it's not a scanning problem.
In this case the problem may be with the viewing card or CAM not inserted correctly. The CAM needs a good push to insert correctly. Also, it is not obvious which way round the CAM goes into the TV. Try both ways. There will be hard resistance if the CAM is the wrong way round. If there is not hard resistance, then it probably needs pushing in a bit more.
If Setanta doesn't show on the channel list, then the problem is more likely to be to do with your signal.
Posted on Apr 18, 2008
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
  • 8457 Answers
SOURCE: Philips 42PF9631D 42 in. Plasma Television
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Posted on Jan 08, 2010
toyladi3
  • 597 Answers
SOURCE: My Philips 42 inch flat screen tv keeps cutting
There seem to be a problem with the power panel of the television that is why it does not power on if you leave it over the night without trying to turn it on.
Flashing the green power LED light simply means there is a problem in the unit that is why it keeps cutting.
Run a check on the power panel of the television to see if there is a burnt capacitor in the unit, then replace if you find any, also, a cold joint can be a cause for the problem whereby, you have the lead on a capacitor or component melted off and bridging two wrong ends together. That can be corrected with the use of a soldering iron.
If you are not familiar with technical activities, i would strongly advice you have a repairman run a check and fix it for you. It should not cost you much and if it is still under the warranty period, then you can take it back to the dealer that supplied it to you.
Take care
Posted on Oct 11, 2010
thunderz
  • 232 Answers
SOURCE: Philips 37PF9431D 37in. LCD Flat Television
Look for a reset switch or button.You could call a TV repair shop and explain problem they might tell you what it is.
Posted on Mar 07, 2011
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Philips 37PF5521D green light flashes 1 long then 9 short
The fault code is '19'. Counting the flashes to philips TVs are given in detail by the link given below. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ You can get details about the fault codes, blinking codes etc:
Nov 14, 2013 | Philips 37PF5521D 37 in. HD-Ready LCD...
Power board for 37pf5521d
hello!
You don't need to replace power supply in most cases. If you can to the board itself, it buried deep under metal shield, up side down, remove it from the set by unscrewing 6 machine screws, unplugging few plastic connectors. Be careful, connectors are fragile, gently move those in every direction, while pulling out male part of connectors. You will find at least 1 "bloated" electrolytic capacitor, remove and replace those. It's good have "in circuit" capacitor checker to determine quality of "hot side" of power supply capacitors. If you won't find and replace those, small: 1mf 10mf or 22mf, your set will start up, might even work fine for a while, then will quit for good! I've seen that happen! If you don't have capacitor gizmo, then replace all small electrolytic capacitors on "hot" side of power supply. "hot" is that side, what connects to main power in plug area, contents one large capacitor, I.C. chip diver, power mosfet, etc. worst case scenario: if you can't replace those parts yourself, remove the board and take to local TV repair shop. It won't cost you that much to do so, compare to complete TV repair.
Good luck,
Alex.
Feb 19, 2012 | Philips 37PF5521D 37 in. HD-Ready LCD...
Volume keeps turning itself up philips lcd tv
this is due to surface mount capacitors going faulty on the side buttons panel. You can simply disconnect the cable from this board and use you remote to control the channels and volume. if you want it fixed you will have to replace the side button control panel which is a cheap part.
Jan 29, 2011 | Philips 37PF5521D 37 in. HD-Ready LCD...
Philips tv powered off and wont turn back on
There is a smt located at 7404 [C-6 Bottom] A common problem, does the tv make a sound like it wants to come on? Location 3239 should be small resistor, 3414 another resistor and a driver transformer at 5402 if it looks burned. See MCM electronics website and see if there is a kit to repair this. Or ask for part #s as per location of problem area mentioned. What you will be doing is changing the timing so all the components will come on at the same time. If this is done correctly you will notice the top of tv screen will flash red, green and blue lines. This will be the new norm each time you turn it on. But it will be OK. This is what the flashing green light is telling you. signed the Green Lantern7!!!!!!!
Sep 03, 2009 | Philips 30PW8420 TV
My philips 37in lcd hdty model # 37pf7320a/37b will not turn on. Green light comes on for a second then a red blinking light. ive tried leaving it unplugged for a few hours but that didnt work. any ideas...
this sound like a power board problem they are nt that expensive if you do i yourself or a coud tech can fin what is exaclty worng on the board and fix or you cn cange the whole thing.
Nov 07, 2008 | Televison & Video
SETANTA
Apr 17, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
Taking TV from UK to Australia
The TV has a setting for Australia in the Digital setup menu, so there shouldn't be a problem.
The mains voltage in Australia is 240V - 50Hz, so you should only need to change the mains lead.
If you decide to go ahead, when you set up the tv:
Switch on tv.
Press and hold "MENU" on the side of the tv.
Menu will appear on-screen.
Continue to hold until menu clears.
Wait.
TV will reset to factory settings, allowing you to re-tune the tv.
Jan 08, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
Phillips 37pf7320a 37in.hdtv-ready lcd
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Oct 16, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Open Questions:
See all Philips 37PF5521D 37 in. HD-Ready LCD Television Questions
Philips 37PF5521D 37 in. HD-Ready LCD Television Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
