Hp photosmart c3180 just hooked up, new, comunicates with computer on all levels. print or copy will not put anything on paper, goes through all motions but does not put anything on paper, new supplied ink cartriges in place what I assume is correctly?????
    Master:
  • 518 Answers
There is no reason for it not to print ink onto the paper unless it's defective or both carts are dried up. I would return it for an exchange.
Hope that helps...
Geno
Posted on Mar 27, 2008
My hp photosmart c3180 printer keep saying check paper when im trying to print or copy something.
please disconnect the power cable from the wall outlet then press and hold the power bottoum for 20-30 sec then restart
and try to print test page and copy if still it not work then follow this instrution mention from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&cc=us&lc=en&dlc=en&product=1146331
if still your problem is not resolved then contact HP toll free number 1800-474-6836.they will replace your printer if its under warranty.
thanks
regards
Hamid
Feb 25, 2010 | HP Photosmart C3180 All-In-One InkJet...
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
Want to print 2 wallet size on 4x6 photo paper
under print options it will pop up a menu saying to "only show options compatible with my computer...." unclick that and it will allow you to select letter size paper again
Dec 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180
Do you know if that control panel in you computer for that printer needs to be told that you are printing pictures?
Some models you do by selecting photo paper.
Jul 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
C3180 will not print as error occurs even when installed
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
The self-test report prints, containing the serial number and service ID.
This should tell you if it is a problem with the unit itself, or with communication between the unit and your computer.
Feb 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printing Problem
Go Applications-utilities-Print Set up utility Open Print set up utility Then Go reset Print system Then go to hp folder-device utilities-hp set up assistant Run hp set up assistant to install the drivers it will fix the Problem
Sep 05, 2007 | HP Photosmart C3180 All-In-One InkJet...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
