Question about Hasbro Fur Real Friends Smores Pony
Replacement parts my child has a hasbro fur real butterscotch horse whoever she has ripped the left ear off and the tail so i was wondering if i could get those two pieces anywere and replace them. thank u
    New Friend:
Lost the cracker to Furreal Parrott
Posted on Jul 23, 2013
    Problem Solver:
  • 8 Answers
Not sure about the ear but here is how to repair the tail. Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
Large horse has no ears
Poor horse... Maybe try the manufacturer to see if they sell replacement parts. I am sure this is a very common problem. Or look on ebay they may sell spare bits and pieces too.
Apr 09, 2013 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony
Hey, the blue and grey wire under the neck fur does not connect to anywhere. It was likely a debug port while Hasbro was testing the ponies. You can try moving the ear by hand when it's supposed to move but it is likely broken inside the head and would need a lot of work to repair.
Jan 06, 2013 | Hasbro Furreal Friends Butterscotch Pony
Saddle, carrot and brush for butterscotch pony
Check oksanas*heirloom*treasures on eBay for replacement tack. You can get replacement carrot and adoption certificate on eBay from bet_em on eBay.
Nov 16, 2011 | Hasbro Fur Real Friends Smores Pony
My husband bought a used butterscotch pony and it was missing the right ear and the tail, where can i get a replacement?
I think it would be better if you can contact Hasbro so they can tell you wether the part is available as a replacement or not.
I got their phone number for you:
800-255-5516
and they also have this website where you can get all the contact information you are going to need from them:
http://www.hasbro.com/customer-service/phone-directory.cfm
Hope this helps!
Aug 07, 2011 | Hasbro Fur Real Friends Smores Pony
Our furreal butterscotch pony has a broken
Can you be more specific? Is the neck broken? Or just the ears?
Nov 28, 2010 | Hasbro Fur Real Friends Smores Pony
I need to replace an ear on my Butterscotch pony
Were you ever able to locate an ear for this horse? Hasbro doesn't sell them anymore... I need one too, so if you found a source, PLEASE SHARE!!! Best of luck!!
Sep 06, 2009 | Hasbro Furreal Friends Butterscotch Pony
Hasbro Fur Real Friends Smores Pony Logo
1,107 people viewed this question
Top Hasbro Toys Experts
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
