Question about Apple Audio Players & Recorders
I have just purchased and ipod shuffle and will not charge am I doing something wrong?
  • Lauren Anderson May 09, 2010
    yes have realised i need ipod software which was not included with purchase of ipod. thanks
  • 1,284 Answers
Hi, Do you have the software from the CD installed on the computer?
Have you tried shutting it off while connected for a few seconds and turning it on again?
Have you tried restoring it and updating the software on it?
After you install the update on the PC, Connect iPod shuffle to your computer and open iTunes. The iPod Updater application
opens.
If you?re using a Windows PC and the iPod Updater application doesn?t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
Or you can read the article on this link to find out more..
http://support.apple.com/kb/TA44551
Take care
Posted on May 09, 2010
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
How do i turn on my ipod shuffle?.......and how long do i charge the battery for?... and how do i know my ipod is fully charged?
  • first i will cover turning the unit on. then i will cover how to charge the unit.
    -Move the power switch on the top of the iPod Shuffle to the "Normal" or "Shuffle" position.
  • Press the play button on the iPod Shuffle to begin music playback. If the iPod does not begin to play, follow the rest of the instructions.
  • Plug the iPod USB cable into the bottom of your iPod Shuffle and then connect the other end of the cable to your iPod power adapter.
  • Plug the iPod power adapter into a standard electrical outlet to charge the iPod Shuffle's battery. Try to press the play button again.
  • Connect the iPod Shuffle to your Mac or PC computer using the iPod USB cable. Then, open the iTunes program on the computer and sync your iPod with your music library. If your iPod Shuffle was frozen, it should now turn on.
  • to tell if the ipod shuffle is charging. Eject iPod shuffle in iTunes, but leave it physically connected to the USB port. The front LED should be orange if it's charging (or green if it's fully charged). If it's not charging (such is the case if it's connected to a low-power USB port on a keyboard), you won't see a front LED. If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
    Aug 25, 2010 | Apple iPod shuffle Second Gen. Silver (1...
    New pink apple ipod shuffle
    Nothing is wrong you are supposed to let the ipod shufle charge a day after you buy it
    now if you charge it again it would probably turn green.
    Dec 20, 2008 | Apple iPod shuffle MP3 Player
    My iPod shuffle will not charge
    If iPod shuffle won’t turn on or respond
    â If the status light blinks orange when you press a button, the iPod shuffle buttons are
    disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
    blinks green.
    â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
    battery may need to be recharged.
    â Turn iPod shuffle off, wait five seconds, and then turn it on again.
    â You may need to restore iPod shuffle software. See “Updating and Restoring
    iPod shuffle Software” on page 26.
    Jun 25, 2008 | Apple iPod shuffle MP3 Player
    Charging Ipod Shuffle
    If your iPod fails to hold a charge and it's more than a year old, you may need a new battery. Here are some other instructions with regard to charging your Ipod properly:
    Hope this helps!
    - TWEAK A/V LAB
    Nov 10, 2007 | Apple iPod shuffle MP3 Player
    13 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Sean Cole
    Sean Cole
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
