Question about Dishwashers
Dishwasher drains continuously
Drain pump on my dishwasher stays on all the time. The filter is clean now and when I pourclean water into the machine it gets pumped out OK. The bottom of thedishwasher is dry now. I checked the little float switch attached to apiece of foam and it seems to be working OK.
Dishwasher is an ASF645 Arthur Martin Electrolux. The model number is 911232112 according to info from the sticker on the inside of the door. It's a european machine.
This started happening after an incident when the filter was clogged upat the end of a wash cycle. I cleaned the filter but now the drain pumpstill stays on all the time.
When I switch on the machine for a wash cycle the programmer doesn'tadvance any further than the initial drain part of the cycle. If Iforce the program dial on by hand the drain pump goes off but the restof the wash cycle doesn't start (i.e. the dishwasher does nothing atall).
Any ideas what the problem could be?
    Problem Solver:
  • 4 Answers
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Posted on May 30, 2008
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
LG 1419LF My dishwasher stops during its cycle, it shows an error message: OE, there is 2 inches of water at the bottom of machine...Please help...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | LG Dishwashers
I have a dishwasher AEG BM335 super cleaning system. I got a message: F2, and machine stoppet washing, all red lights are on. What can I do? Is any hope for repairing? My name: Arna...
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Asko D1706 Built-in Dishwasher
The dishwasher will not drain properly
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 24, 2011 | Dishwashers
Water will not drain out of bottom of machine.
Hi
Daniel
Mar 19, 2011 | Miele G880 Dishwasher
I have a Kenmore Ultra wash 665.16522. The water won't drain completely. About 2 or 3 inches of water will stay at the bottom. I wonder if there is a food catcher, and if so, how do I clean it? JSBravo
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Dan
Mar 16, 2011 | Kenmore 16522 Built-in Dishwasher
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher won't drain properly. Dishes aren't properly cleaned
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Oct 25, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
My dishwasher is not working
sounds like your drain pump may be blocked.
check to see if waste drainpipe is blocked,
if not try and see if your can get machine to drain into a bucket.
if not drain pump may have something blocking it internally if machine has a filter clean it out, if no filter remove drain pump a clean it out or replace if faulty.
i
May 23, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
469 people viewed this question
Top Dishwashers Experts
