Question about Radio Shack Pro-95 Handheld Scanner
How do you set Pro-95 to receive police "Viper Channels" Mine, most of the time is static or beeping, Squelch doesn't help. Is there a software program upgrade for this. Located in Mooresville, N.C. 28117 Iredell County texfoster@windstream.net
  • 35 Answers
There isn't a Firmware upgrade for this scanner and I also do not think it is capable of Decoding these transmissions. My Pro-95 gets the beeps and tones also. This model of scanner was one of the last models R.S. produced before adding the digital capabilities.
Posted on May 23, 2010
I was given a uniden police scanner and I need to know the frequencies and how to get the static out. . Thank you . Rhonda Hansen
First thing to try is to change the "squelch" setting. If you squelch is set wrong, you will hear static all the time and the scanner may not scan. Turn the squelch until you no longer hear the static and the scanner scans.
Nov 07, 2014 | Radio Communications
How do you get static out of a police scanner
There should be a squelch control turn it clockwise just until the static stops.
Aug 16, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
How do I adjust squelch. Squelch is locked on
I suspect you have it in the continuous monitor mode so follow the directions for getting back into the automatic squelch mode.
AUTOMATIC SQUELCH: The FRS is equipped with an automatic squelch circuitry filtering out weak transmission and unwanted noise, usually caused by terrain conditions.
MONITOR:
- This feature turns off the automatic squelch feature, either momentarily or continuously. It helps in receiving signals to its maximum range, but may pick up static signals, too.
Momentary monitor:
- Press the MON button; the monitor symbol will appear.
- Release the button to restore the automatic squelch.
Continuous monitor:
- Press the MON button for more than 2 seconds until a beep sound is heard. The monitor symbol will appear.
- To restore the automatic squelch, press and release the MON button again.
NOTE: You cannot transmit when the Monitor feature is activated.
This comes from the manual I found on-line at:
http://www.michaelknows.com/electronics/walkie-talkie-manual/
Oct 26, 2013 | BellSouth 1011 (14 Channels) 2-Way Radio
I have a galaxy 33hml and i can not figure out how to set it up with the nobs i mean can you help me....
first of all is it set up to a antenna source? if so then turn the squelch nob counter clockwise all the way, then turn the device on. next start at channel one and slowly turn the squelch clockwise until the pin moves or you hear static. then surf the channels adjusting the squelch to to that static point until you find your active station. from there to cancel static between transmissions turn the squelch so that it is just below the static marker.
Feb 10, 2011 | Galaxy Radios DX-33HML 40-Channels Base CB...
Pro 95 scanner squelch does not silence receiver regardless of knob position,subsequently receiver will not scan.
Your squelch control may be back or your control needs to be aligned properly on the circuit board. Ship it in for repair if you wish. dodgem250.com
Mar 31, 2010 | Radio Shack Pro-95 Handheld Scanner
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Pro96 PROBLEM
http://www.police-scanner.info/police-scanner-frequencies.htm you may need to put in the new freq. # a few months ago most went to new freq. #
Jun 14, 2009 | Radio Shack Pro-96 Scanner
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Pro-95 dual trunktracking handheld scanner
the beep are known as "over beeps", they are generated at the end of a transmission by the transmitting raido to signal that the user has taken his or her finger off the transmit button and has ended transmission, like how they used to say "over". as for the hissing, have you tried adjusting the squelch?
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
593 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
