Question about Samsung SyncMaster 175V 17" LCD Monitor
I have this monitor for like around 6 or 7 years and now it seems like the light on it is darkening is that because is wasting?
    Sergeant:
    Champion:
  • 236 Answers
Thats what happens to that of lcd screen they arnt mad to perform that lond considering they are every where and alot out there to acer makes a 22" for 190
Posted on May 09, 2010
My LG monitor blacks out intermittently when warm, I have tried it on another computer so it is a fault with the monitor. It blacks out every few seconds, sometimes it takes longer. It is 2 years old.
after blackout, check the screen as that. look in to the monitor in side angel,
and if you can see darken live image in that and its working. in that condition, your
LCD panel is working and the problem is no light.
in that case you need to repleace or repair the " inverter unit " in that monitor.
that unit makes the high voltage for back light.
after blackout , you cant see any darken image like as that, and or totally power
goes off , that is different problem. for solve that need advance trouble shooting
and can be need advance repair.
Jan 03, 2011 | LG Flatron W2243SPF Widescreen LCD Monitor
I have an Optrel Satellite and the auto-darkening function has stopped working (weeks before I take my journeyman's, wouldn't you know?) It is no longer under warranty....can anything be done to fix it?
I recently learned something new about these helmets. I really like like the fit and comfort of the OPTREL helmets; best I have ever owned, but the dying, irreplaceable battery thing drives me crazy. What makes it worse is that I spent over $400 to purchase mine and it lasted only 2 years. Unfortunately, I trashed my first one, trying to replace the batteries. Don't do what I did, or at least try this first. Hopefully this will restore full functionality to your helmet.
First step is to cover the sensor ports with opaque tape. These are the little ports on the AD Cartridge, which are located below and to the inside of the photo-voltaic (PV) charging cells. Covering these ports prevents the auto-darkening function from working, while the batteries are being charged. I used masking tape which was covered with duct tape so it was both easy to remove and it completely blocked light from passing through. Next step: Prepare a charging source by placing a CFD light bulb in a utility work light fixture. Mine was an aluminum, reflective fixture with a spring clamp for holding it in position. The bulb must be at least 23W (100W equiv.) and probably not more than 50W, to prevent overheating of the helmet and AD Cartridge. There are likely other light sources which will work as well, the objective being to provide ample and constant charging energy without overheating the helmet or AD cartridge. Position the lamp about 6 inches from the PV cells, immediately in front of the helmet so that the PV cells are able to capture as much of the light energy as possible. The lens should not be darkened in this state, due to the sensors being covered. Test by placing a 3x5 card, or something similar, between the light and helmet. The lens should not darken when exposed to light. The helmet can remain in this state for as long as you like. I left mine to charge for 5 days, after which it was able to maintain the darkened state with no issues.
On occasion, I think it may be beneficial to cycle the batteries on this helmet, i.e., discharge and then recharge. This can be accomplished by placing opaque tape over the PV cells, to temporarily defeat the charging function. Place the helmet in front of the light source, similar to the arrangement described above, positioning the helmet in such a way as to trigger darkening of AD cartridge lens. Note that the sensor ports must be uncovered for the lens to darken. Darkening the lens consumes battery power so leave the helmet in this state until the lens is no longer darkened, which could take hours to days, depending upon the condition of your batteries. Test lens darkening by placing something like a 3x5 card between the light source and sensors, which will cause the lens to transition from dark to light. Once the battery is sufficiently discharged, to a point that the lens no longer able to maintain the darkened state, then recharge the batteries using the procedure described above. Do not leave the helmet with batteries discharged, as this could cause permanent damage to the batteries and AD Cartridge. Hope this works for you. Best Regards.
Oct 27, 2010 | Uvex Optrel Satellite Welding Helmet #...
After 5 minutes monitor screen dims--can faintly see the windows screen and then it flickers out and there is nothing. Any ideas?
the monitor may be going into power save mode which it should come out of when you press a key or move the mouse but it sounds like you have tube inverter issues. Your screen has light tubes behind it to illuminate the screen, if the tubes or the inverter develop a fault, then a very dark screen can result as the tubes are turned off. There may also be an ambient light sensor which will darken the screen in low ambient light. If the sensor is faulty, darkened screens will result. If the inverter is failing, you may be able to replace it, contact viewsonic. if the tubes are failing, replace the panel or the entire monitor. If the ambient light sensor is faulty, replace the panel or entire monitor as the sensor is part of the display panel.
Nov 02, 2009 | ViewSonic VG900b 19" LCD Monitor
Wont print period
What about status monitor? Need service? End life service?
Lights blink alternately? You may need to reset waste ink counter. Use SSC utilty. Try to find at indoreset.blogspot.com.
Sep 13, 2009 | Epson Stylus C66 Inkjet Printer
Monitor darkens significantly when viewing some
The monitor might be on 'dynamic contrast'. Press menu on the remote control and does it say that 'magic bright' is on dynamic contrast?
If so, change it to something else and this may solve your problem.
Hope this helps!
Jul 16, 2009 | Computers & Internet
My viewsonic monitor is not working
Considering the price of monitors versus the cost of repair. It would cost less to replace the monitor.
Mar 12, 2009 | MPC Computers Viewsonic E771 17 in.CRT...
Envision color monitor, Model EN910e
Hi..there! Barb,
It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it. Have a nice day!
Oct 22, 2008 | Envision EN-7220 17" Flat Panel LCD...
What is waste toner.
We've printed for years using gallon jugs of waste toner nabbed from Quick Print Shop* dumpsters. We just pop the white plug on our cartriges, fold a paper plate into 4ths, snip the tip to make a funnel, and dump it in a half cup at a time!
*Names changed, LOL
May 14, 2008 | Office Equipment & Supplies
Dark screen of compaq pressario desktop monitor-some time works by just shifting the monitor a bit
the light guns inside of a monitor can weaken with long use..also, the screen itself can lose it's phosphor coating as well..
your service person is correct
Mar 20, 2008 | HP Compaq Presario V2000 Notebook
Samsung SyncMaster 175V 17" LCD Monitor Logo
63 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
