The cd holder tray on my new cd player only moves a quarter of an inch in or out when the button is pressed NAD C515BEE
  • 22 Answers
Have u tried to pull it out the rest of the way or the other thing could be is a belt is broken that drop the cd player down, if its still under warrenty i take it back if not, n u feel comfortable opening it up.
Posted on Mar 27, 2008
SOURCE:
Getting my aiwa to play cds or cassettes. Bought second hand no instructions .lights up won't play can I get instructions on how to get sound?
You don't state the model, so we are running blind here. It should be fairly obvious. For the CD press the CD button. Then press the door button and put the CD on the tray. Then press play or the door button again. If the CD player works it should play the music. Same with the cassette. Drop the cassette into the holder, push it back in place then press play.
Oct 07, 2017 | Aiwa Audio Players & Recorders
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Cd tray will not open when you push open button
Hello. It sounds like the tray button needs to be replaced.
Apr 18, 2014 | NAD C521 CD Player
The DVD tray of my NAD M55 does not open. It cleary reads open and close if you press the button, it then makes some noice, but the tray will not open. Is there any way to solve this problem or to open the...
Your problem is the drive belt has either stretched (most likely) or snapped.
The only way to open the tray and/or repair it is to remove the cover. Please ensure the unit is unpluged if you decide to remove the cover.
Towards the front of the tray you should see the drive motor and the belt but you may need to remove the cover off the DVD tray to gain access to it.
You should then be able to move the belt by hand to open the tray.
If you take the belt off and measure it then get one a couple of mm smaller. Easiest place would be eBay.
Jul 05, 2011 | NAD M55 Master Series Universal Disc...
NAD C541 tray does not open.
if i'm right it will have the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping the cd tray from opening and also clamping the disc properly when closed.
hope this helps?
Mar 11, 2010 | NAD C541 CD Player
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
NAD 5100 monitor wont eject
Hi ntravers9
You could fix this yourself, in saying this of course, you will need to also source a new belt for the player ( I can help you there too) That is probably what is preventing the Cd tray from opening. If you where to remove the lid, and give the transport a little assistance in the direction that things initially start moving, then you can be sure that the mechanism is not damaged in any way, and that a lazy belt is the source of you problem.
Do this if you are into fixing it yourself, to see for sure what is happening and we can go from there.
regards
robotek.
Dec 17, 2008 | NAD C521 CD Player
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
[email protected]
Sep 25, 2007 | NAD C541 CD Player
102 people viewed this question
Ekse
 Grubhead
Grubhead
