Question about Hayward EC-40 DE Pool Filter with pump
D.E. NOT STICKING TO FILTERS - Hayward EC-40 DE Pool Filter with pump
  • 640 Answers
Is this your first time using the pool filter? There are several things that you will want to check. Make sure that the pump is primed and running. Make sure that all air has escaped the filter and that you have a steady stream of water from the return line. Then, you need to pre-coat the filter with DE. This is an important step. Scoop 5 lbs. of DE into you skimmer as fast as the plumbing will take it. You will also need to regenerate when your pressure drops off. Stop the pump. Move the bump handle down slowly, then up briskly. Repeat 3 times. Restart the pump and filtration will resume at near the original flow and pressure. After each regeneration, and until the filter is cleaned, there may be a slight increase in the starting pressure. This is the result of dirt accumulating within the filter and is completely normal.
Posted on Apr 05, 2011
Engine cuts out at stop lights
Most likely IAC dirty or sticking.
Feb 16, 2015 | 2008 Dodge Caliber
My heater and filters seem to be working but my Intex spa will not make bubbles. The blower does not seem to be working and we have only used it twice.
reguardless of how much time elapses between uses the blower unit should alll ways be tested for (Back flow) after every use , this is when water gets back into blower unit and causes rust on drive shaft (sticking shaft) sometimes thiis can be compounded by the mixing valve (a device that mixes air and water ) going bad or sticking open with debris
Dec 29, 2014 | Intex Pool & Spa
Tpi corvette runs rough intermintely then fine
EGR sticking or mixture control solenoid on carburator if equipped
Apr 20, 2014 | 1986 Chevrolet Corvette
Which replacement filters are best
As this is a near new vehicle i suggest sticking with the Genuine Lexus filters, the only exception would be the Air filter, you can buy an aftermarket K&N type which will allow your motor to breath easier and helps with power and economy.
Mar 09, 2012 | 2011 Lexus LX 570
Remove a fuel filter from a 2001 ford econoline
Check in the frame rail on the driver side on the metal fuel line. Ford's been sticking the filter down there.
The filters come with a special tool to remove their special clips..
Apr 07, 2010 | 2001 Ford Econoline
Looking for the best replacement pool filters for Sta Rite s8m150 inner and outer filters. Dont know if I should stay with Sta Rite brand or other relacement options.
I would recommend sticking to sta-rite. They are more expensive but are worth it. The system 3 cartridges are very good compared to generic replacements.
Mar 19, 2010 | Pool & Spa
Empty Water light is on but water container is empty
The float switch could be sticking,or there is a blockage to the water container.
It means a strip down of dryer if you are certain that all filters and vents are are clean.
Hope this helps.
Dec 19, 2009 | Hotpoint Dryers
Want to replace air box filter. Also have a
the sticking problem is usually a fairly inexpensive fix, the cable is beginning to fray, change the throttlecable. as for the air filter housing? k&n makes awesome filters for most bikes!!! good luck, hope this helps!
Nov 19, 2009 | 1993 BMW K 1
Temp sensor
Look for little probe sticking out into return air duct area, beside controls. Usually visible when you take filters off. About 2-3" long and 3/16" in diameter, attached to small brass tube.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Intermittant Engine jerking in reverse or just running up hills
i believe that either the trnas control module is malfuntioning or you have a sticking valve body in the transmission
Sep 26, 2008 | 2004 Buick LeSabre
Hayward EC-40 DE Pool Filter  with pump Logo
231 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
