Question about Refrigerators
I have a 2yr. old Maytag Frig.,freezer on top.I cannot get a stable freezing temp. I can set, with the setting control, readings of 4 or 7 with no effect on the actual temp. I bought a freezer thermometer to verify this problem. The lowest reading has been 10 above by vastly reducing or rearranging food positions. Some so called experts claim that Ideal temp. should be between 5 below & 5 above. Soft Ice Cream has been the result of the problem.
  • Yardrarig Mar 27, 2008
    Do you agree that ideally the freezer reding must be 5 below or 5 above?
    Genius:
  • 3,422 Answers
If the refrigerator is not cold enough then please check the following and also click on the blue coloured links for more info.
How To Check the TemperatureI have a 2yr. old - 1x1.gif In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 27, 2008
  • Priya darshan Mar 27, 2008
    Yes i do agree with that as i have already mentioned "The ideal freezer temperature
    is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge".
  • 3,037 Answers
It could be the control unit, but if it started happening without switching the setting, then it may be a compressor problem.
Clean very well bottom of frigid including compressor, fan and condenser (all in bottom of my unit. Then set both frigid and freezer temperature controls to "midpoint" and never move these from there.
If it is still under warranty, get a professional come look at it if this doesn't help, It will probably get worse and stop working all together otherwise.
Please let me know how this works out.
Good Luck and have a good day
  • Benjamin Patri
    Benjamin Patri Mar 27, 2008
    Never set freezer control higher than mid point. Keep condenser clean
    all the time (should be done once a year). Temp or refrigerator control
    is your thermostat which controls the running time of your compressor.
    In most refrigerator the freezer control only controls a door between
    the fridge and freezer section that opens and closes to allow more or
    less air to pass from the freezer into refrigerator area. If you turn
    the freezer control on the high the door will close more which mean the
    refrigerator section will get less cold air from the freezer. In most
    refrigerator, alway turn freezer control to the mid point or lower.
6ya staff
SOURCE:
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
Frig won't hold set temp keeps freezing things.
Thermostat is defective.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
TOO Warm....fresh food
IT SOUNDS LIKE THE AIR DUCT TO THE FRIG. MIGHT BE STARTING TO FREEZE UP,CHECK THIS FIRST ALSO MAKE SURE TEMP THERMOSTAT IS ON INITIAL SETTING,LET ME KNOW-MIKE
Jun 24, 2008 | Amana ATB1836AR Top Freezer Refrigerator
Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Sep 26, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
