Question about Kenmore 65942 Electric Dryer
Hello, I have Kenmore 65942 dryer. It stopped & does not work at all. What ever I do, even drum does not rotate. No live sign. Please help
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
I have a kenmore 90 series dryer- It is not working - when I push the start button there is a humming noise and the dryer does not start. However if I push the start button and rotate the drum manually the...
You have a "Dead Spot" in your Motor...When you rotate the drum you move it from the dead spot and it continues to run as normal.
If you want to solve that problem then you will need to replace the motor...otherwise just live with it.
Free Answer...Please rate me
Apr 15, 2011 | Kenmore Dryers
Drum wont rotate on my dryer but it still heats up
its either a broken belt or the drive motor has blown up
Jun 25, 2010 | Kenmore 65942 Electric Dryer
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Kenmore 65942 Electric Dryer
Dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 23, 2010 | Kenmore 72972 Gas Dryer
Dryer's drum won't rotate, but heat & timer works.
Hello there:
This is normally caused by a belt that has either broke or the motor for the belt has failed and locked up
S o what i would do is to first see if you can manually turn the drum by hand and if so than if you turn on the dryer and hear the motor that turns the drum running or humming you can assume that the motor is ok and that he belt has failed in this case get a new belt and the appliance parts store should be able to give you the proper diagram on how the belt needs to back on but if not let me know and i will be able to get it for you ok? now if you do not hear the motor hum than try to unplug the machine and leave sit for 30 min and than plug it back in and than see if it now tries to run but if no motor sound than youwill know that the motor has either failed and needs to be replaced or that there is a problem with the thermal fuse that is on the controle panel behind the start button ok
i can help if there is any more issues that you need help with.
Hope this is very helpful for you.
Best regards michael
Dec 19, 2009 | Kenmore Dryers
Kenmore Electric 70 series dryer making noise
can spin motor w/ hand ,,if so pull side by side if no noise ,, inspect rollers,and idler
Dec 28, 2008 | Kenmore 65942 Electric Dryer
Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Feb 21, 2008 | Dryers
Kenmore 65942 Electric Dryer Logo
23 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
