Question about LG Studioworks 700S 17" CRT Monitor
My monitor displaying yellow color in place of white
  • LG Master
  • 4,924 Answers
Right click on the desktop ...properties...settings (should be the last in the right ) ..than advanced..and should display the monitor settings ..there get them one by one cause there are more then one setting and try to default them ...i fthe color is not getting to normal than reinstall the video card ..and after that if is still the same it means that something is broke in the monitor ...and need a proper fix..at the shop ...or ..if it is a cheap one ..just get another form a second hand dealer until you will afford a good one ..
Posted on May 09, 2010
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Hi! I have Acer aspire one d257,it has a clear and vivid notebook display but whenever I connect it to the monitor or lcd the color turns to yellow instead of white background. what will I do?
Sounds like the monitor you are connecting to is bad. Try another monitor.
Borrow a monitor from a neighbor, friend, relative or co-worker. See if it displays correctly.
May 25, 2012 | Acer Aspire One D257 Netbook
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Color Problem
all of you mentioned are correct. if they cannot work on color setting of your monitor and for the setting of your resolutions it could be the monitor. the monitor cannot support the color bit mode which required for the windows vista it could be a 16bit color mode which only display for not more than 63herts for the Hi color vsynch compare for the 256color if you have a Hi color settings for about more than 63herst vsynch. it cannot display properly. thanks
May 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Mar 19, 2009 | Gateway FPD1760 Monitor
Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
Oct 29, 2008 | E-Machines eMachines Monitor E15T4
Monitor color changed
there may 2 problems
1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
Sep 05, 2008 | Gateway FPD2275W LCD Monitor
Color problem
IT is 18 years OLD so has CCFL back lamps that all turn yellow.
is that it? if the OSD is yellow the (white looks yellow) that means the CCFL black lamp tubes are Shot.
i cant see what you see, no photos posted.
ok the monitor has and OSD, on screen display
i see you found that. but then fail to say what you saw there.
"you could see the background on the text as white. "
what does that mean,?
no matter what that is a bad Monitor.
the OSD works with no computer at all, so if the OSD fails
OSD brain, inside, then the monitor is bad.
all monitors worked previously so is not key to why its failing now.
only the tests now, matter. today/
my post above is for any monitor that fails the OSD tests
no PC turned off. or connected to any PC that works
the PC resolution must never exceed
1024 × 768 at 75 Hz Refresh Rate
on this old old dog. or the screen goes back with error
OUT OF RANGE.
Aug 27, 2017 | Compaq TFT5010 (Opal) 15.1" LCD Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
170 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
