Question about Mastercool 67680 Evaporative Cooler Air Conditioner
The drain hose pumps out too much water.
There is a drain hose that runs off of the evap cooler I have on the roof of my home. It has been draining water constantly when it is on and is flooding the ground where the hose ends. Is this normal?
  • 306 Answers
Yes it is if it is very humid and hot you know your unit is working very good. You can take the hose out farther from that spot. Set up a bird bath and let the birds enjoy a bath. just a idea.
Posted on May 09, 2010
Trying to find pump.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful:
To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard.
The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors.
Soak the hose in a bucket of warm bleach water.
Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris.
Reattach drain hose and connect to drain pipe.
Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening.
Run the washer through a full cycle with 2 cups of bleach added.
Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
Oct 12, 2012 | Frigidaire Affinity ATF7000E Front Load...
Hi I have the same issue with my a 2002 explorer xlt 4 door no sun roof. when it rains or goes through the car wash the drivers side seat belt gets soaked and water runs down to the floor board soaking the...
There are drains for the sunroof that are located in the coners of the roof, these plug up and the water drains into car, you will need to remove the cover were the seatbelt is and see if the hose that connects to the drain fell off or if drain is plugged, open the roof all the way back and using a bottle filled with water , pour over the drains one at a time and see if it drains if not you will need to use a coat hanger and unplug them but i would still check for the hose off on the side that leaks water. good day.
Apr 22, 2011 | 2002 Ford Explorer
Have 2 evaps on roof shut main water feed valve off. There is some water in pan of one and dripping on my new roof. Wondering why there is water in pan? can you help
Yes, there should be a water/condensation pan under it with an overflow drain that takes the water down off the roof. Perhaps, whomever installed your new roof, removed the drain tubing and forgot to put it back.
Apr 13, 2011 | Mastercool 67680 Evaporative Cooler Air...
Water leak rear floor driver's side as well as floor back of passenger. Drain lines from sun roof are clear. No rear end accidents. Any ideas? So far dealer cannot find a problem. 2007 Camry Hybrid
Roof drains may seem clear,but are the drain hoses,actually on the roof window frame.
Remove the head liner to be sure
Why can't the dealer use a dye type test or smoke tester. The smoke doesn't just have to be used for EVAP, that it was designed for. And you wonder why I do all my own work?
May 10, 2010 | Cars & Trucks
How do I clean out the vents in my RV Dometic roof ac?
Take it off,the plastic inside vents, with soap water and a hose wash it.  Outside condendor and inside evapator, making sure the drain is open and outside shroad removed, brush off fthe loose stuff. wet both units, put liquid dishwashing soap on both. Spray then through , with a hose untill they rince clean.  While up there. Oil the motor if possible.  Keep the drain clear and open,making sure none of the water is getting into the RV.
May 08, 2009 | Dometic Rooftop RV Air Conditioner
Rain water comes in the car from the top, or moon roof. Is it because the drains are clogged or what?
well the easy way to check is open the sun roof look from the top of the car inside the sunroof is there sitting water in the little drain areas around the sunroof if so the drain is not working... if no sitting water pour some water in see if it drains if it does drain it is prolly the seal isself so if the water drains fine then close the sun roof and spray it with a hose if it still leaks in prolly the seal...if its the drain hose you will have to trace it it useally runs down the a piller let me no what you find or have other questions
Mar 28, 2009 | 2000 Volkswagen Beetle
Leak from pipe/wahing machine drain hose
try running the snake from the top to the bottom. they ell pressure hose ends that you inser into the pipe on the end of a hose and when you turn the water on it weslls and applies pressure to push out whatever is in there. they cost about 8.00 and you can buy them at lowes or home depot. just tell them what you need and that it screws onto the end of a hose for unclogging backed up drains. im not sure whats its called but they will know
Feb 01, 2009 | Estate TAWX700JQ Top Load Washer
Water Dispenser hamilton Beach Water Cooler
my water cooler worked yesterday,today I get nothing from either the hot or cold water? Is this a simple fix or di I start with a new one?
Jun 02, 2008 | Hamilton Beach Water Cooler with Storage...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
390 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
