I have a rca rtd325w home theater. Can I play music cds without turning on the tv...I'm using the hdmi to the tv
  • 63 Answers
Yes you can. The system operates independant of your tv so you can listen to cd's, and the radio without turning on the tv.
Posted on Jun 21, 2010
My RCA RTD325W Home Theater wont play the DVD's it begins to try to read then stops and tells me there is an error can help me fix my problem please?
You most likely have a bad Optical Pickup(laser) Try playing a CD, and see if that works. If it does, your pickup is bad. If you'd like to inquire about repairing your RCA, please visit my website at audioserviceclinic.com. You may contact me there.Thank you.
Jan 07, 2015 | RCA Dvd Home Theater System Rtd325w Remote...
My rca home theater rtd325w will play everything with no sound
Have you selected internal speakers on the menu? Try checking that out. It may be set for external speakers.
Please post on fixya if this solves your problem. Good luck and get back to me if you need more troubleshooting. Include model # Type of television, ie. smart tv or standard and what the settings catagories are. Oh yeah and how old it is.
Apr 07, 2014 | Audio Players & Recorders
HOW DO i CONNECT MY RCA RTD325W SURROUND STYSTEM THROUGH MY COMCAST BOX AND MY TV
Video out on rtd325 to Video in on TV, set tV to correct input source, not red/white cables to Audio or AUX INPUT on the rtd325 and run those to Audio out on the comcast box, set rtd325 to AUX fcuntion when watching comcast
Oct 29, 2013 | RCA Dvd Home Theater System Rtd325w Remote...
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
RCA RTD325W via HDMI cable to VIZIO E320VP - How do I get sound from TV to play out of Home Theater unit? More cables required? Buttons to push? Thank You. F.Frost
The TV has a SPDIF ( coaxial ) digital out socket at the back . Get yourself a digital cable and connect it to the RCA Home theater systems coax digital inputbobhifi_16.jpg
Mar 16, 2011 | RCA Audio Players & Recorders
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
I bought the RCA RTD325W DVD home theater system. The speakers work with the dvd/radio tuner but cannot get them to work with tv. Also have Satellite tv, do I need to connect to something on that? Or is...
Your TV must have a set of Audio Out connections. Connect them to the Aux In on the back of the RTD325W. Then toggle the Line-In/Aux button on the remote until display reads Aux In. System should work.
Sep 08, 2010 | RCA Audio Players & Recorders
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Televison & Video Logo
1,240 people viewed this question
Top Televison & Video Experts
Electro Med Services...
