Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Black spots are appearing on the photocopies taken from canon ir
Hi
Black spots are appearing on the photocopies taken from canon ir 3300
5 Suggested Answers
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
  • 89 Answers
SOURCE: How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
Posted on Nov 24, 2009
  • 89 Answers
SOURCE: how to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Posted on Nov 25, 2009
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
Sir i hav a doubt in canon ir 3300.
Hi. have you tried to adjust density in the user mode?
May 01, 2017 | Canon Ir 3300 B/w Copier image Runner...
I have Cannon 3300 digital photocopier but as soon as I switch on machine an erron appear E000002-0000 and machine is not operating
Hello
what you need to do is just resetting your machine. 1. Press * 28 * on your machine in a quick move. 2. Select copier 3. Select Err. 4. Select Clear then press O.K 5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
otherwise
This code also for Heater Coil Fault. Replace the Fixing Element Coil.
Hope this helps
Jan 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Download standby massage appear
hi;
you should download a new software, use SST and the new software for IR2016i.
Oct 31, 2010 | Canon iR 2016i Black and White Copier
How can i save scaned datas in my canon ir3300 photocopier
what is the problem in imagerunner3300 with the error code No. E191?
Sep 03, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I required Canon Photocopier IR3300 driver
Hi, try this link for your driver:
http://www.givemefile.net/drivers/_xerox_and_ifis/canon/ir-3300.html
Aug 07, 2010 | Computers & Internet
How can i solve error canon Ir2016 (download standby) error
Hi, you need to upgrade firmware from start. Download standby is message that appears when system is colapsed and when you want to upgrade firmware from service mode.
Jun 11, 2010 | Canon iR 2016i Black and White Copier
Hi I need to connect my photocopy canon ir
you must put an ip address,on the machine ( system),and the port of the driver you must put the same ip.
Apr 04, 2010 | Canon iR 2016i Black and White Copier
How do I scan on the Canon imageRUNNER 3300
instalation of photocopier/scanner with pc model no IR-3300. Kindly tell me the procedure to install it and make it functioning...
Mar 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
70 people viewed this question
old marine
old marine
