Question about Rosen CV1022D Car DVD Player
Sound only through headphones not car audio system
I have just solved the rosen g8 problem where sound wont play over car stereo There is a tiny switch on the circuit board that needs to be switched, it was as simple as that i assume that this was the fm transmitter. ok to find it flip down screen then undo the four screws holding system to the car roof so be careful as to support system.unclip the 3 wired connectors, the unit should be totally free now. next unscrew the very small screws and remove cover plate. look for a raised circuit board with a small switch. it is in a 7 o'clock position just off centre, with black switch facing a way from you make sure its in the left hand position , refit cover and screws and fit back into car........ check frequency by pressing speaker symbol on remote or on system and tune radio to that frequency
Posted on Mar 24, 2013
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 19 Answers
Are you using a 3.5mm cable or an rf modulator? if not you wont get any audio
Posted on Nov 05, 2010
    Problem Solver:
  • 7 Answers
On most overhead systems there is a switch or button that turns the sound off the headphones. Also sometimes if the headphones are turned off sometimes that enables the audio to goto the vehicles system. Do you have it directly connected to the cars radio or do you have a wireless fm modulator that you have to tune it to an fm radio station?
Posted on Aug 08, 2010
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Feb 28, 2017 | Vizio Audio Players & Recorders
How do I get the tv sound on after plugging speakers into audio on my TV?
That's what's 'sposed to happen. You get TV sound OR sound through headphones - not both
Nov 28, 2015 | Sennheiser Rs 180 Digital Wireless...
Please solve my laptop sound problem?
Check whether the volume to media level setting. If it is let to extreme low, there will be no audio output, although the system start-up sound can be heard through the headphone.
Jul 08, 2014 | Computers & Internet
Problems with Audio system
If the audio is there when you fit the headphone jack back in, suspect a faulty headphone socket.
Jul 21, 2013 | Audio Players & Recorders
No sound comes out of the system/speakers on my FW-C255/37
There is a problem with the headphone jack or there is a audio output problem, get some electronic contact cleaner attach straw and spray inside the jack, push the headphone jack in and out quickly and spray again and repeat, this should clean the contact points, if no sound, audio output should be suspect.
May 10, 2012 | Philips FWC255 CD Shelf System
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
No sound from headphones from dvd player
Hi.
Ensure that the red and white audio cables to the display are properly connected.
Test headphones on different system.
Try turning off and turning back on the system with the headphones plugged.
Jun 05, 2010 | Car Audio & Video
My laptop sounds from both the speaker when i connect headphone.
First go to control panel, sounds and audio devices
go to the audio tab and make sure that your usb device is selected for audio playback
then, unconnect the headphones and restart your computer
after restarting, connect the headphones and Speakers , it should work
May 04, 2009 | Computers & Internet
Rosen CV1022D Car DVD Player Logo
441 people viewed this question
Top Rosen Car Audio & Video Experts
Jerry Naidoo
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
