Question about Bang and Olufsen Beosound 2000 Shelf System
Hi, my beosound 2500 (1991 mod) totaly froze the other day. i disconected the power cable and fysicly slided the glass open, after that i work.. but when i tryed to youse it sone ours later it was frozen again.. its been like this 2days now.. any idea what the problem could be?? Eirik
  • 2 more comments
  • eirikdahl86 May 09, 2010
    ok, where do i find this capasitor.. and would i be able to do it myself??
    Thanks for quick replay..
    You guys are doing a grate jobb.
    where do i find the thing you are talkind about?
    and will i be able to fiks this myself?
    President:
  • 4,070 Answers
Hi! My suspicion is that theres a mainboard failure. There maybe blown capacitors that needs to be replaced. The capacitor replacement will be better and cheaper than replacing the whole mainboard. Once replaced you'll be good. Hope this helps and have a good one!
Posted on May 09, 2010
  • dj_relly999
    dj_relly999 May 09, 2010
    It can be found on any local electronic parts center. I would suggest an electrician on doing this to prevent damage specially on sensitive parts.
Car is totaly dead put new battery and alternator on it drove for a day now totaly dead again like battery has been disconected
Check glove box / boot light. Temporary remove them charge batry & see if discharge stops.
Jun 18, 2012 | 2000 Ford Mustang
My glass doors only open partly on the 2500 Beosound system If I take off the glass doors the mechanism opens and shut fine . What can the problem be ??
Hi, I am having the same problem.I am thinking of bringing it to a B&O repair centre but if you found a solution, I am very interested to hear it.
Dec 30, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Glass broke on slide piece. where can i get a replacement? and how much?
It is for sure that B&O spares are not available in any common spares shop. Hence either you will have to source the item for original fittment or maybe you can fabricate one with the correct diamension. Incidently this will work out cheaper that the original unless you get lucky to get one from an old set. Hope you decide and think I could help you decide. Good day
Jul 22, 2010 | Bang and Olufsen Beosound 2000 Shelf...
How do I change the light bulb(s) on a BeoSound / overture
Remove glass doors,black panels 8 screws lift up cd clamper and detatch from drive bar at top l/h corner.Lift operating panel to gain access to cable connector behind keypad,this should provide enough room to work on lamps.
May 06, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
Cable on power sliding door broken...will not operate with power...expensive fix?
We'll
speaking from one that has change SEVERAL of these. If you havent done it
before its a pain in the ****. I have done so many that I can do them in about
30 minutes. You can do it with or without the door on the vehicle.
Personally I do them with the door off. You can't fix the cable if its broke.
The cable has to slide down 2 sets of sliders and in and out of the motor
theres no tolerance for a splice anywheres. I had no idea those motor assy were
that expensive.
The way this is changed is
you remove the door. (disconnect negative on battery, or turn power slide door
button to off) Remove the panel, drop the glass down about a 1/3 the way, pull
the 2 rubber grommets off from inside the mod. Remove 2 10 mm bolts, remove the
back sash on the door and the inside rear window rail, pull the inside rubber
window run slightly out. Slide the old glass out, drop the mod down, remove the
cable assy bolts (4 10mm bolts) , unplug the wiring harness, remove the 2 10mm
bolts atop the rear slide roller, theres also one 10mm inside the door at the
very top near the rear slider. Remove that bolt too, its grey and about 1
1/4" long. You also have the remove the rear latch lock, 3 T30 torks
bolts. Unsnap the cable from the 2 retaining clips and slide the power door
assembly out the bottom of the door. Reverse assembly for the new one. Id
imagine they are charging you about $300-400 labor. Id do it for $100
lol No idea where to get a new one
reasonably tho. Its sad cause I see 1000's of them daily. Ask me how I know
this? I work in offline repair at Toyota Motor
manufacturing Indiana.
Originally Posted by BLOWN
86
There's a sequence for that motor if you replace it yourself you
could possibly break it again I've seen those motors split easily just by
letting too much cable go into the motor assembly the spool that holds the
cable can only hold just the right amount to open and close the door
Good luck Rob
I agree,
if you don't know what your doing with the new motor your going to shell it out
quicker then you put it on. This is where the dealer comes in handy. I've
replaced a few and from I've seen they usually run around $1100-1200 without
labor
ABOVE IS
FROM ...
http://www.tundrasolutions.com/forums/sienna/73364-2004-sienna-le-power-door-broken/
How to
fix the problem with $5 ...
http://polifrogblog.blogspot.com/2009/09/i-fixed-power-door.html
Jun 24, 2009 | 2004 Toyota Sienna
Elecrtial problem
Sounds like a newer 5 series. The SZL module located in the steering column has failed. Most common indication of this failure is the wipers being stuck on. Unit will need to be coded by a professional. Just for fun you can try a memory dump: remove negative battery cable and then positive battery cable and touch them together for 30 minutes then reconnect everything and hope for the best. If the cables are too short to reach each other slide a screwdriver in through the negative opening and into the positive opening. MAKE SURE NEGATIVE CABLE DOESN'T TOUCH THE POSITIVE CABLE WHILE IT IS CONNECTED TO THE VEHICLE.
Jun 19, 2009 | 2002 BMW 5 Series
Sunroof doesn"t open or close
Section 01-17: Roof Panel, Sliding—Electric 1996 Taurus, Sable Workshop Manual DESCRIPTION AND OPERATION Electric Operation The sliding roof panel (502B98):
  • is available as an option.
  • is electrically operated through the accessory delay relay (controlled by generic electronic module (GEM)).
  • is of self-storing design.
  • requires a specific headliner.
  • utilizes a unique roof console and dome lamp.
  • has an air deflector.
The electrical system operates in the following manner:
  • Two switches control movement of the roof panel.
  • When the SLIDE roof sliding panel switch (15B691) is rocked rearward, the roof sliding outer glass panel (502A82) slides into the storage space between the roof trim panel (51968) and the roof panel, exposing an opening over the front seats.
  • When the SLIDE roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully back in the storage space, the roof sliding outer glass panel moves forward from the storage position.
  • The rear portion of the roof sliding outer glass panel moves upward on two lifter arms near the end of the forward travel, allowing a weather-tight seal when the roof sliding outer glass panel is closed.
  • An AUTO feature allows the SLIDE roof sliding panel switch to be touched momentarily to cause the roof panel to automatically move to the fully open position.
  • When the TILT roof sliding panel switch is rocked forward with the roof sliding outer glass panel fully forward, the rear of the roof sliding outer glass panel pops up to the VENT position.
  • With the roof sliding outer glass panel in the VENT position, rocking the TILT roof sliding panel switch rearward closes the roof sliding outer glass panel.
  • Sliding Roof Panel Does Not Open or Close
  • Open power feed fuse.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged roof panel
  • Obstructed roof panel
  • Guide
  • Damaged drive cable(s)
  • Open Power Distribution Box Fuses 1 (40A) or 4 (30A)
Apr 19, 2009 | 1996 Ford Taurus
Central locking not working, Chrysler Voyager Limited 2005
hi this works on most voyagers disconect the possative terminal on the battery for ten minites excactly then reconnect and happy days your voyager centrol locking should work ok good luck
Jan 03, 2009 | 2004 Chrysler Voyager
Bang and Olufsen Beosound 4000
Sounds like the belt drive that controls the doors is broken. If you're a repair headed person, you can get the repair manual online for $25 or so. Parts may be harder to get, but with the proper imformation, you may be able to do the work yourself.  It's both tricky and super easy because the design is generally very very good, but knowing the technical details requires a decent amount of patient brain work and proper tools.  DaveA
Dec 02, 2007 | Bang and Olufsen Beosound 4000 Shelf...
227 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Iluvintage
Level 1 Expert
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
