Question about Toshiba Satellite Pro P300 Notebook
Toshiba laptop power failure after yanking power cord
I recently tripped over my laptop power cord and it bent the end right off. I had it resoldered and it was working fine until yesterday it just shut down and went dead. No LED's , nothing. I've removed the battery and held down power button etc. with no luck.
Checking the power supply with a multimeter reads fine, but the internal jack seemed loose, would it likely be the jack causing the power problem or have I shorted the motherboard? I've opened up the laptop but am unsure what to test.
  • sonikcharge May 09, 2010
    Thanks for the assistance.
    Is there particular pins on the connector of the power jack to the motherboard to check? I've had a try and couldn't get a reading. Wiggling the jack does nothing, approximately what would a replacement power jack cost to put in from a repair centre? Thanks
    Also if the power jack was damaged, wouldn't the laptop be able to run off battery which was fully charged?
    President:
  • 3,278 Answers
Hello.
Sounds like you already determined it, but if you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
Hope this helps.
Posted on May 09, 2010
Toshiba laptop is shutting down message but does not caanot use the laptop
If the computer functions when plugged in with or without the power cell, you ok. Just replace the battery. Many times the power plug is at fault. This happens over time because the power cord may accidently be pulled out, (like if someone trips on the cord and pulls it from the laptop). The end of the power cord may become loose, and if so it will not make 100% direct contact between the power transformer and the line in to the computer. You cannot let the power cell (Battery) die. Some computer require a healthy Cell be operational in order to start up and function normally.
Jan 14, 2018 | Toshiba Computers & Internet
Toshiba SAT A505-S6005 Power cord was plugged when laptop fell to the floor and hit where the cord attaches to the receptical (on computer) which jammed (pushed) the thin connector prong further into
When this happens it means that the whole recepticle has been broken off of the motherboard and the whole laptop will have to be disassembled. This is not an easy job for someone who hasn't done one before. After it's disassembled it has to be determined if the recepticle can be resoldered or not. Sometimes the damage is not repairable. Good luck!
Nov 22, 2012 | Toshiba Computers & Internet
My toshiba laptop only works with the battery, once i plug the adapter it turns off and power light blinks every seconds and will never turn on again.
If the computer works fine on the battery, but not on the power supply, I'd guess its a faulty power supply. they frequently get less love than the computer. They're banged around and stretched and bent in crazy ways, yanked from the walls. I'd grab a replacement at bestbuy and if that doesn't work just return the power cord.
Mar 03, 2011 | Computers & Internet
Fuse blew out on my american audio after my girlfriend tripped on the chords, how do i repair it . is there a fuse or a reset button thank you
You are saying the fuse blew out and then asking if there is a fuse??? That makes no sense...
Tripping on cords could do certain things but NOT likely to blow a fuse.
Tripping on cords OFTEN breaks the plugs on the cords or the jacks in the equipment. The power input jacks from those wall transformer power supplies seem to be very vulnerable to this. They often disintegrate OR break loose from the solder on the circuit boards rendering the unit inoperable.
In future, loop the cords through handles so they don't yank the jacks if somebody yanks the cord.
Dec 26, 2010 | American Audio CK 800 MP3 CD PLAYERS SOUND...
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
Batt charge light not on sometimed and low power causes shutdown
you have a loose power connection. this tends to happen if you trip on the power cable ect. it may be in the power supply, but most likley, the socket on the laptop will need resoldered. I have fixed 3 laptops this way.
Aug 19, 2009 | Toshiba Satellite U305-S5097 Notebook
Toshiba P15 S479 Laptop
I had the same problem. The AC adapter connections on the mother board had to be resoldered.
Nov 04, 2008 | Toshiba Satellite P15-S479 Notebook
AC Port shorting out
That definatly sounds like you need to replace the jack for sure....I have fixed two toshiba's with the same problem myself. To get it done in the store you are probably looking at $150-300. Least that is what it was here. So i decided to buy the part i needed off ebay, take the laptops apart and resolder the jack on.
Jul 09, 2008 | Toshiba Satellite R25-S3503 Tablet PC
Mx35 no power
Hi, can you use a multimeter? If so then check on the power suply what the voltage output should be for that unit. Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have. If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit. Regards mistyman
Sep 01, 2007 | Toshiba PA2502U - Libretto 100, 110,...
Toshiba Satellite Pro P300 Notebook Logo
284 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
