Question about Acer Aspire 3004WLCi Notebook
When my battery is installed, the touchpad does not work...any ideas?
  • 74 Answers
Try with another battery. If problem still remain, means your motherboard or touch pad problem. Cause battery can cause other thing malfunction or system hang or very slow
Posted on May 09, 2010
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
Touchpad not working on 5650 Any ideas Thankyou
1.choose option for FN+F7
2.you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad
3.uinstal and instal the touchbad driver via device manager
Nov 17, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
My touch-pad mouse is not working in A135-S4527 Can you help? Thanks.
Try to power drain the laptop first.Turn off the machine, unplug ac adapter and remove battery.press and hold power button for 10 secs then put the battery back and plug ac adapter if needed. turn on the computer and check if touchpad is working if not then check touchpad settings in taskbar, check if touchpad is disabled if not or if there is no icon there go to device manager(right click on mycomputer->properties->device manager)and look for driver for touchpad under mice and other pointing devices.If driver is not there then you have to reinstall the driver. If you have the disc from the manufacturer of the system then run the disc and install driver or if not go the manufacturers website and then download he driver from there.Make sure you restart the machine after installing the driver for it to work properly, also check if the laptop has a button to enable/disable touchpad...some laptops has that kind of feature...Cheers!!!
May 15, 2010 | Toshiba Satellite A135-S4527 Notebook
Can not get my touchpad to work
Try unplugging the battery and rebooting without it. I have same fault, but I have no idea how to solve it!!
Mar 14, 2010 | Acer Aspire 3000 Notebook
Sony vaio touch pad not working.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
Oct 28, 2008 | Sony VAIO VGN-SZ460N/C Notebook
Touchpad Not Working
If you has been installed the right drivers, it is hardware problem.
Try to use the factory touchpad program for your sony touchpad and see what happen (not only the driver, also the program touchpad software)
Oct 06, 2008 | Computers & Internet
Keyboard/touchpad freezes when the battery is plugged!!
I SOLVE THIS ISSUE 100% WORKING
THE MAIN PROBLEM IS ON THE CONTACT BETWEEN THE BATTERY WIRES AND LAPTOP
IF YOU MOVE THE BATTERY IT WILL WORK SO SURE THE PROBLEM WITH THE LINK BETWEEN THE BATTERY AND THE LAPTOP
SOLUTION : TO MOVE THE IRON OUT OF THE LAPTOP TO THE RIGHT TILT THEM TO RIGHT SIDE A LITTLE BECAUSE THE BATTERY WIRES IS TO THE RIGHT SIDE (WATCH THEM) NOT IN THE MIDDLE AND AFTER THAT PUT A STICK ON THE BATTERY TIGHTED IN ITS PLACE SO IT WILL NOT MOVE ITS NOT FREEZING NOW THANKS
Dec 21, 2007 | Acer Aspire 5100 Notebook
Touchpad doesn't respond
MY SOLUTION - Hello, I have Compaq Presario V2000 Laptop and at once my touchpad stopped working.
So i rebooted it several times but it still didn't work.
Then i detached the battery from the laptop and let it like that for 5 min. I attached the battery again and the touchpad was working again.
So, try the simplest solutions first before you start messing with complicating solutions.
Good luck !
Nov 11, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3004WLCi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
