Question about Sony Televison & Video
My sony wega tv not a flat screen older trinitron model the standby light is blinking and can't even get the tv to turn on because of blinking light
  • 3 more comments
  • rosario3562 May 09, 2010
    THE MODEL NO IS KV-32FS120
    I can't turn on tv with remote or manually
    it blinks 5 times then pause
    M sony wega tv model KV-32FS120 won't turn on the standby light is blinking 5 times then a pause. I can't turn on tv with either remote or manually
    that didn't work so I guess it is the picture tube. Thanks for your help
  • 10,594 Answers
Let me know model number of your Sony tv to diagnose problem properly.
Thanks.
Posted on May 09, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics May 09, 2010
    Thanks for model number info.
    How many times red standby light is blinking, there would be 3 seconds big pause between blinks.
    It is incorrect white balance error, that means picture tube is not producing correct white level.
    Please adjust screen volts of picture tube. Screen volt control knob is located on flyback transformer.
    If you have no idea about tv repair then ask local tech to do so.
    Hope this will fix your tv problem.
    Thanks.
    OK, unplug tv from wall socket for minute to get it reset, replug back in and turn On tv that might solve your tv problem.
    help
    Adjust screen volts that might fix your tv problem.
  • Sony Master
  • 5,807 Answers
Hi
rosario3562,
Thanks in advance for choosing Fixya for assistance,
If the standby light is blinking , it only means that your TV have entered
into Protection Mode, and have succeeded not to inflict further damage.
Inside the TV , There is a Microprocessor that detects each circuits
on the TV from OVP , OCP , Horizontal and Vertical Deflection
Circuits the moment it starts up , and halts the system from turning
on if there is a failure in any of the circuits mentioned.
You may need to post what Model , chassis number , year perhaps
of the TV, and the things you have done to remedy the cause.
These unit have dangerous voltages inside ( even when it is unplugged ),
and may require component level troubleshooting.
Might as well post the number of blinks your TV is having to narrow
down the possible causes of the symptoms.
More details , means more possible solutions.
Hope to have a response from you soon , as we can provide the possible
solution to your problem.
Regards,
palaboy
  • 5 more comments
  • Rommel Cana
    Rommel Cana May 09, 2010
    Blinking 5 times means:
    Check the 200 volt line at power up. If it only goes to 130 volts then it means
    Flyback
    is not working.
    There could also be component failure , a resistor or a Discrete transistor in the Video Circuits.
    Check video out ( IC702 TDA6108JF) , Q700, 701, 703 and other components on the C board, also
    check Q562, 561, 564, Q530,Q532, Q531 on the A board.
    Also unit be in IK blanking, try turning up screen slightly.
    Picture tube would not be an issue cause , the TV still doesn't have sound.
    These circuits can be diagnosed and troubleshoot even without the CRT connected and the
    C Board.
    Here is a typical service position
  • Rommel Cana
    Here are additional checkpoints on the M-board :
    IC633 is a Low Voltage Regulator ( 3.3 V ) that supplies IC 001
    Input Voltage of IC633 is +9V
    There is also a supply voltage on pin 42 which can be suppressed by:
    Check also for Q515, and associated components
  • Rommel Cana
    Rommel Cana May 10, 2010
    here is a additional info, schematics on the flyback section:
    Have a check also on D531
  • Rommel Cana
    Rommel Cana May 23, 2010
    here is another and simple way , to verify , if it is really the CRT.
    Remove the CRT socket , with the Board ( Unit unplugged ).
    The unit will turn on properly if the CRT is really bad.
    If it does not, then CRT is not the issue.
  • Rommel Cana
    And if an antenna is connected or other source, it should produce a normal sound on the speaker,
    with the CRT disconnected.
  • Rommel Cana
    and when troubleshooting , there is no guessing.
    Voltage reading and measurement is a must and necessary to identify and find the real cause.
    Hope these guides helps and guide you, even though,
    it might have been already awarded or credited on somebody else.
    Although I maybe the last but I hope , I never be the least.
    Hoping you'll find the solution in a right way.!
  • Rommel Cana
    Rommel Cana Jun 25, 2010
    here is a guide , how to remove the CRT board:
    Follow the arrow directions gently but surely.
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron---Blinks 9 times, won't come on!
A specific model number will probably get you more specific
help.. but if you check around the internet by model number
you will likely be presented with some SERIOUS PART opportunities...
The FASHING LIGHT means you have a hard fault in the power circuits...
The number of flashes is mean to point you to a specific area...
I gave all my big flat screens away in favor of the new
HD stuff... (certainly less reliable than those Sony sers...
Shopjimmy might be a great place to call... but the MODEL NUMBER is a MUST.
TV Parts Universal TV Stands DLP Chips ShopJimmy
May 18, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
391 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
