Memorex dvd/ vcr combo model mvd4544
Hello Guru,
Please I need your help.
I have a dvd/vcr combo unit that the dvd tray door wont open.
I called memorex they suggest I unplug from the power for an hr to re set, that was supposed to open the door when plugged back into pwr, that did not work.
Another tech suggested that I gently pull or rush on the tray door while pressing the open button. That did not work. I have a dvd in the unit that I need to get out. Is there anything else I can try short of taking the cover off the unit? If I have to take apart it will be my last option. How long should I have it unplugged from the power outlet as not to get shocked when I open the unit? Is there some time that it takes for the electricity to drain out of it?
Thanks in advance for your help.
Lisa
  • asilinc298 Mar 28, 2008
    Thank you very much, I will try smacking it first if that fails then I will take the unit apart.
    Brigadier General:
  • 6,966 Answers
Hi Lisa,
Often, tray door refusing to open is a mechanical problem such as stuck-up mechanism, slipping (or cut) belt, blockage or in some case dislodged disc.
An un-technical solution would be to give it a not so gentle whack on the top cover just right above the loading try location while pressing on the eject button. This is not a corrective solution but simply a possible way of getting the disc out. The idea is to jar the mechanism into action.
The correct repair procedure would be to open the unit and determine which area/section needs attention. Often this could be a simple case of dried up lubrication in the any of the mechanical/moving parts or a slipping or severed belt. In some extreme cases, it could be a defective motor or logic/servo controller. In any case, opening the top cover often would allow you to manually remove the disc.
In reply to your last inquiry, electronic devices of this nature would need a couple of minutes or an hour maximum to dissipate whatever stored electrical energy is left inside.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 28, 2008
JVC DR-MV80B display says hello then shuts itself off.
On electric board you need to change the STR,and work fine.....
Sep 09, 2012 | JVC DR-MV80B DVD Recorder / VCR Combo
My memorex dvd shows a split yellow pscan sing
On most of the Models there is a Pscan button on the back of the unit in the middle. just turn that off and you should be good to go.
Aug 22, 2009 | Memorex MVD4544 DVD Recorder/VCR
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Having problems connecting dvd vcr combo to tv
Hey Pat. Red Yellow White Plugs into back of MVD4544. Red Yellow and white plugs into back of TV. If you have an older TV that has only coax cable outlet, go to Radio Shack or Best Buy and get an RF Modulator. You may need to get another set of Red Yellow White Plugs if you have a cable box. The front connections are Video 2, if placed on the back they are Video 1. When you first turn the DVD/VCR player on, be sure to select the appropriate setting. If you figure out how to timer record on this please let me know. No where in the 52 page book is there any info and their website is a joke. Good Luck.
Sep 14, 2007 | Televison & Video
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
