Open Control Panel - Sound and Audio devices - check the sound volume, move to high if required and Mute is not selected. Next click on Sound tab and select a Windows and click on the play button, if the play button is greyed out then the audio driver is either not installed or not working. In this case install your model audio driver.
1. Press the Open button on your remote control 2. Press the Setup button on your remote control 3. Press the 9 button on your remote control for Region Free, or 1 for Region 1, 2 for Region 2, and so on. 4. Press the buttons 2, 0, 1 and then 0 on your remote control in order, one at a time NB: If this doesn't work, you should try pressing the buttons 3, 0, 1 and then 0 instead NB: If this still doesn't work, you should try pressing the buttons 4, 0, 1 and then 0 instead 5. Press the Step button on your remote control 6. Press the Shuffle button on your remote control 7. Press the Next button on your remote control
To fix low sound output volumes when connecting to your TV via SCART on later firmware versions:
1. Press the Setup button on your remote control 2. Press the Stop button on your remote control 3. Press the Step button on your remote control 4. Press the Angle button on your remote control 5. The word RFOUT will appear on screen briefly and the sound will now have been adjusted to normal levels 6. A secret menu will appear, inside which you can scroll down until the words Debug Item appears, where the current region status is displayed
To convert this player to Multi-Region on earlier firmware versions:
1. Press the Setup button on your remote control 2. Press the Title button on your remote control 3. Press the Step button on your remote control 4. Press the Next button on your remote control 5. Using the Up and Down buttons on your remote, select the region of your choice or Bypass for region free 6. Save and then Exit the menu
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off and the Program Button works For Sub Title other Buttons have other functions for The MemorexMVD 2022 Only thing You Have to work the sound From Surround System are TV.
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustmentsthere click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar hope this helps
Hi, click on the "Start Button," in the (right pane) Control Panel, next in the category listings, select Hardware and Sound, open, and click on the "Manage Sound Devices." The Sound window will open; click on the "Playback" button, there should be a Speakers Icon, click on it, look below to find the "Properties button, click to open the next window. In the next window there will be (4) four buttons "General, Level... First click on the "General" button, in the top of the window there will be a "Driver" button, click on that button to open. Select to "Update Driver," just click on it, the drivers will be updated for you. Next you ca go back and press the other areas, Speaker Level etc... Note: "Remember to click on the "Apply and OK buttonsafterward to make sure the changes take effect. "Restart the computer to finalize the changes." "Rate the solution on it helpfulness, its away of letting me know if you resolved the problem or you needfurtherassistance, thank you."
You need to install sound driver in order to get it worked with your new operating system. Installing MSUAA before installing sound driver may help (try using Win Vista sound driver). Go to this link to download:
Check your audio section in bios, if it is enabled then boot the computer and go to control panel and there you have to select "sound and audio devices", now click sound button on the screen and play the windows sound given on the screen your play button will be activated after you select the windows sounds,
If it works then ok else you have to uninstall your sound driver and reinstall the perfect driver for the laptop model
you can explore following link for the audio driver
OK you need to install the Audio manager software, and the software that controls those buttons. Go to the web site and get them and install, after you do, all buttons will work, and you will be able to access the Mic. If you go to sounds in control panel. and click SOUND, then RECORDING you should find controls there? You must configure it before it will work. It still may work without audio manager installed, the buttons will not, you need this.
