Zx-i945lm4 .cannot install windows in 40 GB SATA
Zx-i945lm4 .cannot install windows in 40 GB Seagate SATA hard disk. There is one more 40GB IDE HDD connected in the same Mobo.2.8 P4 HT + 2GB DDR2 667Mhz simmtronnics.
  • 69 Answers
Set bios for sata to legacy and try again also make sure the drive boot order is correct
Posted on May 09, 2010
Please, give me a Sata driver for this HDD
The driver you need is for the onboard IDE/SATA controller. Locate the make and model of your motherboard, visit the support site that they have online, download the driver for the IDE/SATA/RAID (if applicable) controller.
Mar 24, 2014 | Fujitsu 40GB MHW2040BS SATA Mobile 40 GB...
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
How do i install seagate st3500320as 500 gb sata internal hard disk on a msi 845pe max2 series motherboard. i have installed the hard disk, but it is not detected. presently i have a 40 gb ide hard disk...
ther are jumpers betwwin the data cable and power cable of hard disk...ur 40gb hard disk will be on primary...if u are attaching ur hard on same cable u should put jumper on Secondry
Mar 10, 2009 | MSI : 845PE Max2-FISR...
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
