Question about Whirlpool LER8648P Electric Dryer
My gas dryer whirlpool lgn2000jq2 starts ignights the gas and then goes out no heat
My lgn2000jq2 gas dryer starts up, but no heat. i checked the element, its good. checked for 120 volts at element plug, no power there.
Posted on Jul 10, 2011
My whirlpool gas dryer model # LGN2000JQ2 works and heats up but after a few minutes stops blowing heat, just cold air
Most common issue are the coils on the gas valve. On front part of burner. Easy to install and not expensive. Could be cycling thermostat, but I would lean toward the coils. First thing to always check is your vent. The chute that your lint screen goes into sometimes fills up and restricts air flow. Causing unit to short cycle.
Mar 31, 2011 | Dryers
Whirlpool LGN2000JQ2 Dryer will initially light and reach temp normaly, then it will not relight just continue tumbling. Shut off dryer wait a few minutes and restart
I am assuming that it is a gas dryer even though it shows it is an electric. This is a good website
http://www.applianceaid.com/gas_dryer.html#noheat
Dec 02, 2010 | Whirlpool LER8648P Electric Dryer
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
My problem is when i start my dryer it ignights and runs till it heats up and the the flame goes out till it cools off and then ignights and so on
Hi- Sound like the high temp. thermostat is tripping. You may try running it without the vent attached and see if it will run that way. I have had this happen when the vent is too obstructed and the heat cant get out fast enough. Otherwise have someone out to look at it. Hope that helps a little.
Sep 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't dry
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Model DLE2516W, will not heat up. lint catcher is clean, but unit only puts out cool air. it is only 2 years old.
check the pipe that goes outside make sure it is clean also. if so there should be a door or panel one the bottom of the dryer remove and see if this area is clean also, if so with the panel off start the dryer and see if the ignighter glows red . the ignighter mast reach a certian glow before the gas valve will open this could be the problem. let me know how this goes
Aug 16, 2009 | Dryers
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
Burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
Whirlpool LER8648P Electric Dryer Logo
222 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
