Question about Whirlpool EL7ATRR Refrigerator
Area under bottom crisper drawers fills up with water & leaks out onto the floor.
    President:
  • 949 Answers
Hi, it sounds like a defrost drain issue. I put together some information on how to remedy this. Follow the link and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Posted on May 09, 2010
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
Water in bottom left crisper drawer and under drawer
I'm sorry to say that it sound as though your door gasket may no longer be sealing correctly.
For me, it's simply a task of getting a replacement gasket for that make and model.
To remove the old one you would, simply, peel the inside of the gasket toward the outside of the edge of the door revealing the mounting screws. Remove these screws all the way around and replace with the new one in the same fashion...
The reason that I recommend this is that humid air outside of the refrigerator can seep past a worn gasket and condense on the inside surfaces making its way to the bottom and into those drawers.
Feb 16, 2014 | Whirlpool Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
I have a Gibson mode lRM18F6DMGA bottom mini freezer refrigerator that leaks water under the crisper drawers and eventually through the seal onto the floor. There is a ice maker in the freezer but I turned...
Sounds like a clogged drain line. Find the drain and blow or clean out the clog. Drain usually travels from the freezer coil area down to the drip pan, which is usually back bottom.
Apr 15, 2008 | Refrigerators
Whirlpool EL7ATRR Refrigerator Logo
304 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
