Question about Lasko 5362 Heater
The fan makes an odd noise as if it were out of
Lasko heater mod 5362, The fan makes an odd noise as if it were out of balance. Where can I find a wrench to disassemble it?
    Problem Solver:
  • 5 Answers
Recalled: Discontinue use and see
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
Posted on Dec 08, 2010
How to grease or oil a lasko fan model u15700
when a fan makes noise while turning,means the bearing is,
starting worn out.best to replace it.when its not turning,its allreddy,
overheated.
Jun 05, 2014 | Lasko Max Performance Pivoting Utility Fan...
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
Samsung rs2530b refrigerator making loud noise...why?
It might have dust in it. It can drain the fan speed, which makes odd sounds. It could be something else jammed in there too. Clean the fan and see if that works.
May 28, 2012 | Samsung RS2530B Side by Side Refrigerator
I have a Lasko 5141 Ceramic Electric Heater, and when I turn it on, I smell burning and the heater makes a whining noise. I've tried vacuuming it, should I try again or is there another step I should take?
You have an excess amount of lint buildup inside the ceramic element, you need to take the unit apart to clean the element. The fan housing covers the backside of the element and blows the air forward, over a period of time lint builds up.
You need a qualified person to take it apart safely and clean it. It takes a Special Chinese Triangle Bit screwdriver to remove the 2 tamper proof screws from the back. Purchased mine at mcmastercarr.com
Triangle Bits
a7atriangles.png?ver=280340775941a14p1s.png?ver=23707593
These power bits have a 1/4" hex shank and are 2" long.
Size(A) EachTA180.070"5941A11$3.77TA200.083"5941A123.77TA230.090"5941A133.78TA270.100"5941A143.77
Feb 22, 2011 | Lasko 5141 Ceramic Electric Heater
I have a lasko model 5362. the lower control knob is cracked. i need a replacement. please advise.
That model is under recall. DISCONTINUE USE
Also models 5132, 5345, 5364, 5420, 5532, 5534, 5566. For recall information see:
Dec 03, 2010 | Lasko Heating & Cooling
Stopped working after smelling hot.
Recalled
Sep 15, 2010 | Lasko 5362 Heater
Mine lasko 5132 is shutt off 5 or 10 mts after tunr on i clened but is the same problem
Hi, I fixed mine. Spread the word far to everyone that has one. Borrowed an air blower (the kind used to blow away leaves etc), and just blew it inside the cracks and back end of the heater, got all the dust out. Previous reports that the sensor was probably being blocked with dust is correct. Thing has been running more powerfully and doesn't shut off like it did previously. So, just take something with high air pressure, and get all the junk out. No need to even disassemble.
Dec 29, 2009 | Lasko 5132 Ceramic Compact Heater
Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
Lasko 2535
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Mar 09, 2008 | Lasko 2535 Stand (Pedestal) Fan
Lasko 5362 Heater Logo
535 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
