Question about Nokia 6210 Navigator Cell Phone
Side of phone cracked and all my numbers are on there!! no display
  • 68 Answers
OK if you have Nokia PC Suite installed on your computer just plug your mobile phone to your computer and fetch the contacts from PC suite easily
Posted on May 09, 2010
Model Sydney RCM 128=LCD only showing the lower half of letters / numbers on the Display Panel. Can this be corrected to show the full letters/numbers.
These problems can be the result of a bad chip (integrated circuit) on the display board or controller or a simple loose connection. Loose connections happen mostly in mobile applications due to vibrations, bumps, etc. Almost everything can be repaired - but often it is simply not worth the expense. You may be able to make a repair to a loose connection on your own if you have some soldering skills.
"Before" shows a small crack around the post. The component on the other side was disturbed before the solder at the bottom cooled completely, resulting in a cold solder joint. Adding a small amount of solder repairs the joint to "After".
The first thing to do is determine if there is a loose connection or "cold solder" joint as shown above. Only attempt this if the radio is a mobile radio - or otherwise powered with less than 30 volts or so. Base radios (connected to your home's AC mains) should be brought in for professional service instead. First, check for a loose connection while powered up by attempting to slightly move the display. Apply pressure to the top, bottom, left and then right side. Watch closely for an indication of the bottom segments of the LCD turning on. Next, open your radio to access the display PCB. Duplicate the movement if it turned on the display, again. Look at the areas that connect the display PCB to other parts with solder. Try to find the places that expose a crack while moving the display. If none are found, look for the location(s) that are stressed when the display is manipulated. If the display is not turning on at all, look for cracks on the PCB associated with the display. You may need to try to get some movement of this PCB(s) to get the display to flicker on and off. It is very important to keep fingers and tools away from the small coils of wire on the PCB(s). The slightest deflection of the coil can cause major problems for the radio and the operator if it transmits out of the intended band. If you can not get the display to flicker on and off, there is probably a component that has failed. This will require pro service to locate and correct. Likewise, if you are unable to determine the soldered point(s) that when moved, cause the display to flicker, or are uncomfortable soldering small parts, etc. you should bring the radio in for pro service.
If you decide to attempt a repair, a small, 15 to 30 watt iron is maximum size to be used. Gently heat the suspect solder joint(s) to restore the connectivity to the display PCB. If you located a cracked PCB, the silver "traces" on both sides of the crack will need to be joined. Sometimes, a small blurb of solder can bridge the crack, other times a length of wire is needed to do the job. Use only as much heat is required to melt the solder. Too much heat will damage the PCB and / or components on the PCB. When done, carefully inspect your work. Look for accidentally "bridged" connections, as shown in the red circle in the image below:
You may need to solder wick or solder vacuum bulb to clear these bridges. Check your work twice and reassemble to test.
I hope this helps and good luck! Please rate my reply. Thanks.
May 31, 2011 | Radio Communications
Lg phone screen cracked but when you look it closely it doesn't have crack lines. crack lines only appears when it is turned on and not present when the phone is turned off why am i suppose to do?
The glass of the lcd screen is not cracked, but internally the display is'nt working perfect, few lines are not displayed on the screen which makes us to assume that the screen is cracked which is not the case, you need to replace the display, it its one or two lines you can use the same display screen, their won't be any damage to your phone due to non display of few lines.
Jul 29, 2010 | LG Televison & Video
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Phone parts
Sorry for your luck on that, I ran a repair center a number of years ...if no OTHER buttons is ajar and stuck on then i would consider a crack in that PC board that holds the buttons. Might be able to find it easy by opening it up and looking there for small crack (lite board up from back side helps spot it) if break at ground maybe all buttons failing if power line open at crack just that button fails
Nov 22, 2009 | Dual Electronics CECT P168 Cellular Phone
Horizontal lines on front display
The screen has cracked. If this isn't a physical damage andthe phone is under warranty; you must take the phone to the nearest nokia care and avail the warranty.
regards
Sandeep
Oct 19, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Screen crack
you could use the A/V adapter cable you received whith your phone? if you connect it to your n95 and your tv then you can see your phone display at monster size?
Oct 21, 2008 | Nokia N95 Cellular Phone
Casing crack
change the mobile panel and put cover to the mobile! if display have cracks mean buy display stickers and paste it to the display! just try it
May 07, 2008 | Palm Treo 650 Handheld
Nokia 6210 Navigator Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
