Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
The dishwasher fills up with water, and will pump out the water, but no water is going to the spray nozzles. The compartment is just steaming up. What could be causing this?
  • Kenmore Master
  • 12,061 Answers
Http://appliancejunk.com/ge/dishwasher/31-3280.pdf
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
Ok, please use these links above are for service manuals, they will show you how to troubleshoot and hopefully repair. the link above, is a troubleshooting how to.
Posted on May 09, 2010
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
My Indesit dishwashers lower spray arm comes off resulting in flooding do I need new arm support
Yes. The water pressure in the hydraulic system is very important.
If more water flows through the hydraulic circuit of the lower nozzle, then probably that the upper nozzle will not rotate which will cause poor wash results.
Dado
Oct 25, 2015 | Indesit Dishwashers
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
The dishwasher appears to not pump water through the spray arms. the nozzles are not clogged and both are not rotating. any assistance would be appreciated
what makes the circulation in the dishwasher? the circulation pump. just check the water going in and the water going out.
Mar 06, 2010 | Dishwashers
Spray arms not turning in dishwasher
Water pressure makes the arms move, so your pump must be defective
Aug 28, 2017 | Dishwashers
I have an LG model LG8812st dishwasher and the spray nozzle under the top rack does not rotate. It turns freely by hand but it appears there is no water geting to it through the connection on the rear...
Either the pump is not able to pump due to clogged pump or there is not enough water in the tub after filling to get up to the upper spray arm.
Sep 05, 2009 | Dishwashers
Will not dispense water how do I trouble shoot bissell proheat steam carpet cleaner
Listen to see if you can hear pump run when pressing button, if the pump does run, than either you have a clogged nozzle or screen in water fill compartment.
Jun 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
LG Steam Washer
please give me some more details like model number. that will be easy
Apr 10, 2008 | LG WM-2277HW Front Load Washer
Nespresso Magimix M300 'Fill Water'
it just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Sep 16, 2007 | Coffee Makers & Espresso Machines
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
613 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
