Question about Kitchen Ranges
Why does my gas digital range stove throw a breaker when I open the oven door?
Door to oven locked wont open
u can try unplugging the range for five min , if that dont work , get its electrical checked out
Apr 21, 2010 | Kitchen Ranges
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
"Door locked" indicator light on, but able to open/close oven...
Unplug the stove. Remove the oven control plug and check between the 2 pins going out to the door lock mech if the meter reads open circuit the door lock switch is bad. If the meter reads continuity then the oven control is bad.
Sep 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven and controls dont work but the stove is?
usually it is the element that blows or burns out turn off power to range at circuit breaker, open oven and check element for holes, power still turned off!! unscrew element from back of stove wall, this is easier if the oven door is removed, open door to first detente (stays open by itself a few inches in open position) grab door on either side (not by the handle it will break off) and lift upward, check if wire connections are good, if not repair the connection(s), do you have a volt meter, if not borrow one or buy a cheap one and check the voltage at the connections, make contact with the meters probes and isolate them from the oven's walls (use some electrical tape) turn on oven and then turn on power at circuit breaker if 220v is available then the element is bad, if you do not have 220v then the switch is bad or wire feeding the switch is bad
Sep 16, 2009 | Whirlpool Accubake RF362LXTS Electric...
Throws breaker when turn oven on
is it a new larger stove,then it could be a power supply deficiency,otherwise an element is bad or shorting to unit case and causing a trip
Aug 14, 2009 | Frigidaire FEF375E Electric Kitchen Range
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Replace oven UI -KitchenAid KGRS807SSS Gas Kitchen Range Problem
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
Oct 19, 2008 | KitchenAid KGRS807SSS Gas Kitchen Range
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Apr 07, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
