Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
We can only get sound, no picture when trying to play our wii on our Sony Bravia TV
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
  • 1121 Answers
SOURCE: Need to get sound for wii w/ sony bravia tv and sound system
you must use a tv headsets jack or on wii output (RCA Connectors red/white) or Fibre Cable Wii output
Posted on Nov 29, 2009
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
welcomejee
  • 10594 Answers
SOURCE: No picture or sound. Red light
Just a correction, it is not necessary that 4 times red light blinking always shows inverter board problem.
It depends on chassis/ model number of Sony bravia tv to what is error code of 4 blinks as it would be mentioned service manual.
I'm Sony tech and can help you, let me know model number written at back of tv to provide you exact info about 4 times red light blinking.
Thanks.
Posted on Aug 18, 2010
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
How to set Sony Bravia tv for sound only
Do you mean you want the TV to display no picture yet be playing the sound from a TV show? If so, sorry, there is no "audio only" setting for this model.
Aug 22, 2014 | Sony BRAVIA KDL-32M4000 32" HDTV LCD TV
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
We just bought a new sony bravia. The cable, dvd sound comes through a bose system that is hooked up to the tv, but we also have a wii game system that is just connected on the side of the tv. there is no...
you should be able to connect the wii to a port at the back as well try doing that cause sometimes you don't get a full connection using the side ports if that doesn't work then make sure all cables are not loose that is the main cause of lose of sound or picture
Feb 02, 2011 | Televison & Video
No sound or sound from my wii on a sony bravia 42"
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
click here to download repair guide
Dec 08, 2010 | Nintendo Wii Console
Get a picture but no sound
Unplug,replug the tv about an hour later.Let the tv reset it self.Go to the menu,go to Audio setting,go down reset.The tv audio will work again.Not,than ur Tuner board is dead.Must be repalced.
Apr 26, 2010 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Wii "invalid format"
Back-up games cannot be played until you get your Wii modded. if you didn't do this yet, you cannot play them. Your TV has to do nothing with it, its the format you put on the CD.
Tip: Try to use Verbatim disks, they can be read on the Wii.
Tip: You need to put the file on the disk as a ''.ISO'' format.
Dec 03, 2009 | Nintendo Wii Console
There is usualy a 2nd channel for games like example - video 1 is video games but hear the tv, video 2 is videogames and hear Wii. Hope it helps
Nov 29, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do you hook up a wii to this thing?
ok u can hook it up though a dvd player if ur tv wont support it make sure ur on the right channel though
Dec 25, 2008 | EA Sports Tiger Woods PGA Tour 08 for...
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
