Question about Vector Maxx SST Power Inverter
I plugit in and turn the inverter box on, one
I plugit in and turn the inverter box on, one second later noise & fire inside the box i unplug the freezers and the noise and fire stop, now is no power on the box.
    Guru:
  • 290 Answers
The problem you are experiencing is as
a result of an overload.Your inverter is
200watts and i believe your freezer has
a higher power than it, i.e.it is above
200watts. When ever there is an
overload on an inverter it distroys the
power transistors that make the
inverter work.You will need to see a
local repairs person.
Posted on May 10, 2010
Started making a loud buzzing noise. Have tried unplugging it and turning it off and on.
Good Morning Denise, thank you for your inquiry!
From the information you have provided your Frigidaire freezer is making a buzzing noise and it will not stop. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If the buzzing continues I would be happy to research your freezer further, in order to do so I would need your model number. You can locate the serial tag (which lists your model number) on the inside wall. Once I have that information I would be happy to help you further. -Matt
Mar 08, 2016 | Frigidaire Freezers
Why my amana freezer is making a lot of noise i have to turn it of on on for the noise to stop/
if noise is coming from inside freezer,,, the fan is probably hitting ice buildup,, and when you unplug fridge it thaws and noise goes away for a few days. sounds like a defrost problem.. either therostat is bad or heating element is broken and needs to be replaced
Aug 31, 2014 | Amana Refrigerators
Kenmore Elite Trio 596.76529500 It makes a
It is the Freezer Fan, he ice maker fan. I experienced the same conditions of a two year period. The tech allows said either unplug overnight. I as you couldn't take the noise. Oh by the way it will be getting worse!!! The solution replace the Freezer Fan motor.it cost about $78.00 plus shipping. they are located behind the freezer rear wall. They are very labor intensive to replace because the electrical leads are attached just out of reach. I have a 33" arm and I had to act like a contortionist to unplug them.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Jenn-air 46-37333 side by side refrigerator
Goto the back of it, this could be because of power failure check to see that they're plugged in nice a tighty, if they are, check your fuse box, turn everything off and back on again.
Aug 08, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Vector Maxx SST Power Inverter Logo
278 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
